Old 05-26-2020, 11:42 AM   #155
stevieturbo
Drives: it changes
If you can change the bracket or tensioner setup to the likes of what ECS sell, or the ESS setup, IMO it is a far better layout.
Or presumably you can just unbolt the tensioner and then refit it ?
stevieturbo is offline   Reply With Quote
Old 05-26-2020, 11:59 AM   #156
eLeSthree
Drives: 2011 Camaro SS 6sp
Have you tried a Continental Elite V-belt? I have a Gates HD green belt as a spare, but I see more boost with the Elite. The Green belt is fuzzy and smooth on the inside, just seems like it would slip easier. I believe they are only designed to last longer, not grip more. The Continental is rubbery and has "teeth".
https://www.summitracing.com/parts/cel-4100755
The ESS kits run about a 75 inch belt, so this part number wont help you. Sorry. If you can find your size, it would be worth the small investment to give it a shot.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 05-26-2020, 03:44 PM   #157
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by racesloth View Post
A few pics of my belt situation. First two are of the 64.9 inch belt (K100649) you can see the tensioner is almost maxed out even with the tensioner in the lower position. I boost it max out on tension and then the belt slips or contacts the lower belt.
Third pick is of the 64.3 inch belt (K100643) which does not even come close to fitting even with the tensioner removed.
In my searching I cannot find a 10 rib belt in between 64.3 and 64.9. I am open to suggestions.
You can see Vortech only uses one idler pulley. I am following Ted's guidance to run under the idler, while the Vortec instructions say to run it over the top - but that would result in the upper part of the belt touching the lower part - two or three idlers with a tensioner pulling up would be better - think ESS or ECS.
I don't recall,,, Does the lower Idler have a lower hole option?
Are you running the Larger Crank pulley?
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 05-26-2020, 06:26 PM   #158
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
I am running the larger crank pulley (7.8"). Unfortunately the Idler does not have a lower hole option. DSX makes a 4" Idler pulley that might be worth trying and I am looking into an ECS larger lower pulley 8.25"...maybe one of those tow options would help....
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 05-26-2020, 07:18 PM   #159
stevieturbo
Drives: it changes
IMO, try and modify your kit to this type of pulley/tensioner arrangement. It is a far superior design.
https://www.camaro5.com/forums/showthread.php?t=179689
Old 05-26-2020, 07:59 PM   #160
racesloth
Dan
Changing brackets will be last resort... But maybe that is the way it will go. Seems I am stuck between everyone's belt sizes. If someone made a 65.25" 10-rib belt... How can I be the first guy t have this problem with a YSi on vortech brackets?
Dan
2010 IOM SS
Old 05-26-2020, 10:00 PM   #161
Big Biscuits
Big Biscuits's Avatar
Drives: 2010 1SS LS3
ESS moves the Two pulleys and tensioner around to give you a good wrap.
2010 CGM 1SS
408/4L80E/ZL1
ESS G4
Big Biscuits is offline   Reply With Quote
Old 05-27-2020, 02:01 AM   #162
stevieturbo
Drives: it changes
I'm sure it wouldn't be rocket science to adapt the good tensioner system to existing brackets.
Old 05-27-2020, 06:05 AM   #163
eLeSthree
I highly doubt you want to redo your entire bracket design, and I dont know if the pulley alignment will even be compatible with your crank pulley, BUT, if this can help you in anyway, you are welcome to it. Just cover shipping.
This is the Vortech bracket for the ESS kit. It has holes for two idler pulleys, and the third idler mounts on top of the stock idler on the alternator bracket.
Its hard to believe that the Vortech bracket doesnt work though.
1158whp 1017wtq.
630whp 658wtq
Old 05-27-2020, 04:26 PM   #164
racesloth
Dan
eLeSthree,
Thanks so much for the kind offer - I am in comms with ESS pricing out the rest of brackets, pulleys and tensioner. Depending how much they want total, I will take you up on your offer.
Thanks again,
Dan
Dan
2010 IOM SS
Old 06-10-2020, 10:05 AM   #165
racesloth
Dan
Well, replaced the stock 3" idler pulley with a DSX 4" idler pulley (bolted right into the Vortech bracket) and a grip tech 3.3" pulley which also just bolted in.... Car feels much stronger - will run some logs to check for boost and belt slip.
Dan
2010 IOM SS
Old 06-17-2020, 05:33 AM   #166
eLeSthree
NICE! DSX can make just about anything with their new cnc machines. If that works, it would be a really easy fix. Good luck.
1158whp 1017wtq.
630whp 658wtq
Old 10-12-2020, 09:29 AM   #167
racesloth
Dan
Well broke the diff - haven't taken it apart yet - traveling this week. either ring and pinion or carrier.... Ho humm.
Dan
2010 IOM SS
Old 10-12-2020, 12:26 PM   #168
eLeSthree
I feel your pain. My trans is on the floor again. This hobby has its ups and downs.
What tire are you running? Did it break at the track?
1158whp 1017wtq.
630whp 658wtq
cam, id850, twin disc, whipple
