09-28-2016, 07:52 PM | #15 | |
Drives: '16 2SS, '14 Z71 Join Date: Sep 2016
Sorry about that. I see now you posted this ages ago HAHA. I was about to say even the cam specs are different on a manual. (minor but different) so there is no way it is the same hardware. Well sorry I was late to the game.
'16 2SS M6 & '14 Z71
09-29-2016, 10:03 AM | #16 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
So does that mean the gen 6 manual LT1 cars don't have the AFM lifters?
MJK3888 Instagram Link
09-29-2016, 11:00 AM | #17 | |
yeah, so youre 1LE would be a pretty sweet track car with a aftermarket cam with mild ramp rate...and now we know could be easily done in a weekend. |
09-29-2016, 11:52 AM | #18 | |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
When i'm in tour, my afm behaves normally. In sport, it's completely disabled. |
09-29-2016, 12:07 PM | #19 |
09-29-2016, 03:25 PM | #20 | |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
Interesting as I had them in mine. I personally removed them and replaced with LS7 lifters and a Katech AFM delete cover. I have seen and heard of too many failures from the poorly designed AFM lifters and sustained high rpm driving, especially with the addition of aftermarket camshafts.
URR2SLO - If you're not going fast enough, get out the way......
10-01-2016, 01:18 PM | #21 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
http://www.camaro6.com/forums/showth...=462141&page=2 So you have a manual '16 Camaro SS that did in fact have AFM lifters? |
10-01-2016, 03:02 PM | #22 |
Drives: 2016 2ss Join Date: Aug 2016
Seems like we have some conflicting information out there. Both users visually confirmed that they either did or did not have the afm hardware in their 16 m6 ss. I wish there were some more clarification on this as it will probably sway me one way or another as to which upgrades I do first on my car.
10-01-2016, 03:12 PM | #23 | |
Perhaps Livernois will provide build data for the vehicles they have seen....or perhaps they misunderstood the question they had answered. We all know by now that the 16 Camaro with manual transmission does not "use" the AFM function, but all LT1 engines I have seen have had the parts installed. Would be interesting to have a mid year change like that without an RPO designation change, I would think anyway.
10-01-2016, 03:15 PM | #24 | |
10-01-2016, 03:23 PM | #25 | |
10-01-2016, 06:14 PM | #26 |
Here are some pictures. First picture is my transmission...it's a manual. As you can see there are 8 AFM lifters. They go to cylinders 1, 4, 6, and 7. They are clearly different and have the springs attached to them. Also shown is the VLOM or Variable Lifter Oil Manifold. It controls oil pressure to the AFM Lifters to either make them open the valves fully or collapse them to make approx. 25PSI in the cylinder. You can also see the camshaft sprocket fastener in the picture. Notice it has holes in the housing as to control oil for the VVT actuator. I did not remove VVT, but the fastener is a one time use and I figure some people might find it interesting as most people don't have the opportunity to see all the parts that go inside their engines.
I checked with my parts guy and he said all 6.2L Di engines have AFM and even the same camshaft. Interestingly, his catalog shows the same camshaft part number for a 6.2 in a Camaro, Corvette, Silverado, Sierra, and Escalade. All with the same VLOM and Lifters part numbers and quantity. I'm pretty familiar with my car as you can see I've changed quite a bit. Camshaft, Headers, Supercharger, CAI, etc. I can confirm my car did have AFM parts installed from GM.
10-01-2016, 06:42 PM | #27 |
Thanks!!! Very good info and evidence! Not what I wanted to hear though.
I would really like to see similar pictures from Livernois. If theirs really did have all non-AFM lifters, then the possibilities I can think of are 1) running change or 2) plant deviation allowing use of the auto engine in some manuals. Out of curiosity, what was your build date? |
10-01-2016, 07:45 PM | #28 |
Build date was October 14th... I think. It was an early car for sure
