11-20-2018, 03:41 PM | #1 |
Drives: 2017 2SS Join Date: Jun 2016
Recalibration of MRC Ride Height-Dealer says Chevy doesn't know anything about it
Is it called something else?
I guess I should try another dealer? Thanks for the advice, Brian 2SS w/MRC |
11-20-2018, 03:42 PM | #2 |
After installing lowering shocks
11-20-2018, 04:31 PM | #3 |
yup try another dealer they idiots
11-21-2018, 08:21 AM | #4 |
Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
Should be known to the dealer - the 1500 Denali owners require this for any suspension height changes as well.
Sounds like a lazy service department.
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
11-21-2018, 09:54 AM | #5 |
It took them 2 hours before telling me they could not get my 3/4" lowered car on their alignment rack and that Chevy HQ does not know anything about adjusting MRC Ride Height!
11-21-2018, 09:57 AM | #6 |
Maybe I am petty but I have been given the wrong information from many dealers. I mean from different makes also so after I get a solution I go back and act like I'm being helpful. I make sure that I am repetitive and act as if I am just trying to be helpful.
2018 Camaro 2.0t Automatic |
11-21-2018, 10:52 AM | #7 |
Drives: 2ss Nightfall Grey Join Date: Dec 2016
Ray-J, that's a fantastic capture of your car....what side of town are you?
11-22-2018, 08:19 AM | #8 |
Drives: 2021 300 Join Date: Jan 2015
This is why dealers and owners alike get confused.
It's not a warranty or repair issue. It's a performance parts upgrade with installation bundled into the cost. That's why some people are getting turned away when their cars are out of warranty, or some dealers are saying the car already has the latest software. They're treating it as a warranty repair. It is not a warranty repair. It is not service. It is installation of aftermarket performance "parts". Need to see a Chevy performance Dealer, I believe its about $350.00 |
11-22-2018, 09:46 AM | #9 | |
Drives: 2017 2SS A8 Black Join Date: Mar 2017
There are actually two things the dealer can do to the MRC (I think)....one is an update of some sort and the other is this level adjustment. From what I've been reading, due to how MRC functions, if the vehicle height changes, this height/level/trim has to be reset. I believe this is a sensor/software setting that a competent GM tech can perform in less than an hour. I am not sure what or how the height/level sensor functions so I don't fully understand to accurately describe what changes are made. Vehicle height changes not only come from the lowering, but from tire/wheel dimension changes also. The terminology "calibration" or "re-calibration" may not be what is done but is used frequently as a common misnomer. There are some good articles on the web about MRC functionality and it is a really simple design. If some GM tech could chime in I'd like to know more about it, especially the type of sensors and feedback. My MRC ride is a little "looser" now and when I bring it in for service, I will have them make this adjustment. It is Hendricks so I believe they will know what is needed.
Man is born free, and everywhere he is in chains
11-22-2018, 09:52 AM | #10 | ||
Agreed it isn't a warranty issue, unless it malfunctions at stock ride height. Quote:
11-22-2018, 10:09 AM | #11 | |
"spring rates" is why I selected BMR springs which are not variable. Do you know what type of sensors are used?
11-22-2018, 10:35 AM | #12 | |
Wheel/tire changes do not change MRC sensor positions as the geometry isn't affected.
11-22-2018, 10:45 AM | #13 | |
May be as simple as resistance readings then....ok. So they re-zero it at the new position so to say..... Thanks!
11-22-2018, 10:48 AM | #14 |
Is there a sensor on all four corners?
