07-19-2019, 02:20 AM | #1 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
How many heat cycles out of SC3's
Hi, how many heat cycles are you guys getting out of your stock GY SC3's?
I see guys saying they are getting 5 to 6 track days, and obviously that's track dependent, but what about the number of heat cycles.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
07-19-2019, 07:13 AM | #2 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Run them till they cord unless you like throwing money away...
07-19-2019, 03:18 PM | #3 |
So you're saying they will cord before heat cycles become an issue?
07-19-2019, 03:29 PM | #4 |
I don't think heat cycles effect a 200tw tire enough to notice a difference. I run my G3s till they cord and they still perform great.
07-19-2019, 03:41 PM | #5 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I am almost done with my second set (street driven, so they see more heat cycles than most track dedicated tires) and they have little fall off all the way down. Obviously the best grip is the first 1/3 of the tread life, but they hold up very well.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
07-19-2019, 04:10 PM | #6 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
Maybe I am misunderstanding the question, but don't tires go through a heat cycle every time you drive on them?
07-19-2019, 04:20 PM | #7 |
Drives: 2020 Camaro ZL-1 1LE Join Date: Jul 2018
Not sure about the heat cycles but the more I drive on these tires the better they perform. Getting worn now and the turn in is great. Better than when new.
07-19-2019, 06:04 PM | #8 |
Yes they do, assuming you drive them more than say a mile and not just around the block.
Current:
07-20-2019, 06:48 AM | #9 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Agreed . . . but I doubt that all heat cycles are created equal.
Norm
'19 WRX 6M (the family sedan . . . seriously) |
07-20-2019, 06:45 PM | #10 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
The only consideration with G3s is how much tread is left for water evacuation. Other than that, they grip till they cord and number of heat cycles dont seem to affect them much (as stated above already). Having said that, note that any tire will be fastest when just starting a session after a warm up lap. Eventually they will fall off a bit with more laps especially if they slide a lot. So if ya try to go for a PB do it early in a session. Then ya need to cool them down to get peak performance again. In longer races that's what called "managing tires". Ciao! |
07-20-2019, 07:11 PM | #11 | |
Drives: 1LEs Join Date: May 2009
To what TrackClub said about water evacuation, neither tire is the best (at all) when new in standing water, so, with the sipes backwards, if you flip the fronts on the rim, they will not exactly be a good thing in the wet. We drive to and from our "home" track [Motorsports Ranch - Cresson, TX] 90 miles one way in most cases (vs. trailering), and of course, after a bunch of driving and track heat cycles, they aren't as good at the end of their life. However, they still are good enough... |
07-20-2019, 08:51 PM | #12 | |
Rotating wheels L to R is a no brainer, albeit logistically problematic, unless one has at least 1 spare wheel to facilitate a switch with. Or a shop with a lift near by. Ive seen guys put a whole front on jack stands before, but this is way over my safety tolerance. Call me timid NB i have experienced an absolute deluge, while on a concrete hiway and nothing bad happened. The G3s had 3 track days on them. Of course i slowed down and after a short while ended up exiting to wait it out safely. Would i like to experience the same situation with more tire wear? A definite no. Having just checked my tires with 4 days of hard running at CW venues and quite a few miles of back and forth dd, my left front still has a middle main channel, a wee bit of an inside one left and almost none of the outside main channel. The right front is similarly worn but in a bit of a better shape (of course). Rotating them left to right would be ideal about now. The rears are much better. Would i be concerned with wet surface? No. Standing water? Likely. By tomorrow i will have 5 days on them and hope like heck it is sunny during my long trip home |
07-21-2019, 07:27 AM | #13 | |
I think I just took this picture for illustration-of-concept purposes; the front being up on low ramps being the explanation for the blocks behind the same end apparently being jacked up. Picture taken at some unknown time prior to having the house re-sided and re-shingled. Norm
07-22-2019, 07:37 AM | #14 | |
Tags |
heat cycle, sc3, tire, track |
