01-05-2023, 08:17 AM | #1 |
Black lightning
Quick question on obd scanner
Is it okay to leave the obd scanner plugged while going wot since that’s the only time the cel flashes? I’m trying to catch the code because there isn’t anything pending
[ 2021 Camaro ZLE 10 speed
01-05-2023, 08:31 AM | #2 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Did the flashing CEL not store a code? It doesn't have to be continuously lit to have a code in memory.
01-05-2023, 09:28 AM | #3 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
Flashing usually indicates a misfire, may not be captured by an OSB scanner
01-05-2023, 10:15 AM | #4 |
Flashing cel is a random misfire. You are not going to get any other info with a code reader by leaving it plugged in. Check plugs, wires, and harness on passenger side if you have headers.
2016 NFG 1SS A8
01-05-2023, 10:25 AM | #5 |
Shouldn't be any problem with it. A lot of people plug them in for data logging at WOT. I did with my 1994 Camaro without any problems (it was OBD I).
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
01-05-2023, 05:12 PM | #6 |
Had a flashing CEL on my Honda and it set a code for a misfire on cylinder 5. It only did it under hard acceleration and went out once I backed off the throttle. Ended up requiring a software update to fix.
01-05-2023, 05:37 PM | #7 |
Black lightning
Nope nothing stored nothing pending
01-05-2023, 06:04 PM | #8 |
Wow. That's not good. Sounds like a run with the scanner plugged in may be the next step. How do they expect you to find out which cylinder is misfiring if it won’t store a code?
01-05-2023, 07:16 PM | #9 |
With a fancy scan tool that can show live, realtime data from the ECM and other modules.
01-06-2023, 08:39 AM | #10 |
Black lightning
Yea I’m here now at Koons chevy if they don’t see anything it’s gotta be from the BP gas
