02-20-2019, 02:42 PM | #15 |
Drives: 2018 Camaro ZL1 A10 Join Date: Nov 2018
This is a misconception we see a lot. The factory stuff is generally the hottest. The factory cast iron manifolds are basically heat sinks that retain he and take a while to cool down. Also, stock the cats (which get pretty hot), are much closer to the engine.
When you go stainless headers, even if peak heat might be a little higher, it does not retain heat like the factory cast iron. Also the cats are moved under the car and further from the engine. Because of that, uncoated headers run a little cooler than stock. The best is coated headers, which you can touch 10 minutes after a drag race. We have a great free coating special going here- https://www.camaro6.com/forums/showthread.php?t=546571 If you have questions or want a great deal, call us @ 610-628-1563 |
02-20-2019, 03:17 PM | #16 | |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
02-20-2019, 03:22 PM | #17 | |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
I used DEI spark wire boots for mine and I can tell they were needed because there is limited space with the headers being so close to the boots.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
02-20-2019, 06:09 PM | #18 |
Drives: 2018 Camaro SS 1le Join Date: Dec 2018
I wonder if porting stock heads would help vs aftermarket
02-20-2019, 10:42 PM | #19 |
if you want to get them coated send them to http://swaintech.com/race-coatings/ the others are just paint.
02-20-2019, 10:51 PM | #20 |
Drives: 2018 1SS 1LE HBM Join Date: Jul 2014
Pretty much just added peace of mind. As mentioned the boot sleeves just protect the spark plug wires from contact and the heat of the headers given the close fitting.
02-20-2019, 10:57 PM | #21 |
Not sure. I removed the stock headers during replacement with lth and stock starter heat shield and then fed the heat shield wrap around the starter. Took a few minutes and some patience to feed it up and around and get it where needed. Don't have a mental image of it anymore with the headers in place from underneath, short term memory, lol. My memory tells me you would need to remove the factory starter heat shield 2 or 3 bolts if I remember right, but may be able to do with headers on, just a pita.
02-21-2019, 08:10 AM | #22 | |
2016 NFG 1SS A8
02-21-2019, 09:06 AM | #23 |
Yes and to add to what king said, peak temp is 95% of the issue. That’s what will melt things. In stock form it is designed to run indefinitely without melting components. cool down time is really insignificant to components compared to running temps
02-21-2019, 09:40 AM | #24 | |
We have been dealing with Jet Hot for years and I can assure you it is more than "just paint"
02-21-2019, 03:11 PM | #25 |
Drives: Chevrolet Camaro Join Date: Feb 2019
Really good points here. Thanks everyone for the input.
02-21-2019, 03:12 PM | #26 |
Would you say that a good coating on headers brings it manageable or "safe" levels?
02-21-2019, 06:43 PM | #27 |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
my two cents;most paint/powercoat shops offer ceramic coating services, just so you know.
i always have that done and it seems to hold up great. it is expensive though, especially because of the complexity of long tubes. like CSP was saying, you can touch the coated stainless part shortly after running it. pretty nice stuff
02-21-2019, 08:15 PM | #28 |
Drives: Camaro Join Date: Sep 2018
Been using Jet Hot since 1987, WAY better than most I've seen.
