Old 02-16-2019, 01:01 PM   #57
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Originally Posted by ShizzySupra View Post
Awesome! Kind of expected numbers/gain on a lower spun set-up! Should be fun!
I want to check the boost now with the kooks, might have lost a lb. So maybe with a smaller pulley some of these mods would show greater returns? Although I feel I will be pushing the stock internals with creeping up towards 700???
Even still it should be a solid setup, can't wait to hit the track and lay down some sub 10.50's.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 02-16-2019, 09:36 PM   #58
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Nice results! I think my next mods will be headers, 3.25 and e50 mix. Should put me around 650 with a 5th gear pull.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 02-17-2019, 12:20 AM   #59
Drsagacity
Drsagacity's Avatar
Looks like you are being held back by your cam and fuel, right? I think you are right about the forged internals next.
I absolutely love the flat torque curve and the hp line that pulls straight to the finish...absolutely beautiful! Congrats on the great setup.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 02-17-2019, 05:19 AM   #60
Hilltopper
Drives: 2018 Camaro ZL1, 2017 Z06/Z07
Originally Posted by Jhunsberger View Post
Picked my car up last night from CSP! Everything seems great so far. Final results are 653/618. Was hoping for a little more but overall I am happy. Once the weather allows it will be time to bolt on my drag tire setup and hit the track.
That's about the perfect street setup right there!! 650-700 rwhp is the sweet spot, in my opinion. TQ curve looks flat and strong!! At that power level, I wouldn't think a forged bottom end is mandatory unless you are going to pull the engine for the cam upgrade, ect. At that point, it would probably make sense to upgrade as much as you can, depending on what your goals are at that point. In any event, you have a badass setup!!
___________________________________________
2018 ZL1, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, ATI Underdrive Pulley 673/688, 2017 Z06/Z07, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, IW 18% Underdrive Pulley 640/664, 2019 Mustang GT Perf Pkg. 1
Hilltopper is offline   Reply With Quote
Old 02-17-2019, 06:21 AM   #61
wnta1ss
I keep seeing this kind of thinking on this site and it's not valid. With a supercharger, how fast you spin it IS how hard you are pushing it, not the boost number itself. 'Boost' is just a restriction number and it can vary with changes to other parts. So what you did (leave the pulley alone) is a proper test of your mods. If you had changed the pulley, that would be a further mod, and then you would not have known what these mods (cat deletes to long tubes, normal CAI to big gulp, 87mm tb to 103mm tb) actually did.
Old 02-17-2019, 07:19 AM   #62
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Exactly. Read Ted Jannety's thread where they added headers. Boost went down and power went up. Why? Reducing the restriction in the exhaust reduced back pressure in the cylinder, let more air in and increases power while dropping boost pressure and lowering IATs. Win-Win-Win!
Old 02-17-2019, 09:49 AM   #63
steelheadrob
Tactical Garage
steelheadrob's Avatar
The TQ curve is impressive holding strong out past 5,000 rpms, where as before it starting dropping off at 4,500. HP gains are strong from 5,000 rpms and up. You should definitely see some improvement at the track.
steelheadrob is offline   Reply With Quote
Old 02-18-2019, 05:42 AM   #64
Jhunsberger
Thank you everyone for all the comments, reactions and info along the way. I didn't give it any thought about the benefits of dropping boost but still adding power. Thank you for pointing that out.
This community has been a valuable resource, I cant imagine doing this all over with out it.
This will probably be the end of my major mods, I doubt I will head down the forged internals, piston, rods, cam, heads route, not unless I have to.
I have a fan override switch to install yet and will probably hook up a wideband to my P3 gauge, thats about it. Maybe a trunk mounted coolant tank.
Old 02-18-2019, 07:55 AM   #65
KingLT1
KingLT1's Avatar
I was just looking back at your Dyno graph and noticed the power goes flat from 52-5600rpm. It doesn't do that on your previous Dyno. Wonder what is causing that?
2016 NFG 1SS A8
Old 02-18-2019, 10:05 AM   #66
Jhunsberger
I noticed that too, and waiting to hear back about that.
