10-03-2017, 09:44 AM | #29 | |
Drives: 18 Colorado ZR2, 17 1LE(sold) Join Date: Aug 2013
Ed has the best of both worlds from a comfort standpoint imo. 1LE looks with the regular zl1 ride. A lot of members run 1LE replicas and could easily wrap their hood and mirrors black. I hope that won't bother you with your inbound 1LE. |
10-03-2017, 10:13 AM | #30 |
Drives: 2016 Camaro 2SS A8 Join Date: Dec 2015
MP concepts just came out with a ZL1 front end that fits the SS almost perfectly. It is $1000 unpainted. No modifications necessary. I actually saw this on an SS very recently. The lines match up very well and the guy only had to get it painted and installed. It does not come with the ZL1 badge but does have the splitter already built into it. I thought the car was a ZL1 because it looked so good. This could be a much more affordable option if you want to go aftermarket for this mod.
https://www.americanauthority.com/pr...e-front-bumper |
10-03-2017, 11:37 AM | #31 | |
Dyno Show Queen LOL
It's unfortunate that my order took to long my date keeps moving.. If you want my allocation it's yours..3300 status lonestar chevt houston tx..remember this is a zl1.. now the only difference is adjustable coil overs vs mag ride.., 19 inch tires vs 20, and solid bushing vs rubber. I drive mine alot it be a better car for more road and the 3 or 4 track days I do.
11-05-2017, 10:52 AM | #32 |
I just bought a 2018 ZL1, ran through some road debris that damaged my front Fascia the first week I had it and am wanting to replace it with the 1LE front end. I see you posted the major parts, but is that everything? Mine is at the body shop right now so I'm trying to avoid delays by accidentally not getting every single part they need to put it together. So any help would be GREATLY appreciated.
I was thinking I may need fender liners as well, but not sure. Anyway, here's what I have ordered so far... 84177344 Spoiler 84280755 Fascia 84291360 Fender 84291359 Fender 84222508 Grille 23329726 Deflector 23329727 Deflector 84277492 Bezel 84277493 Bezel 84277490 Grille 84244390 Deflector 23329728 Deflector Pkg 23329729 Deflector Pkg 23329723 Harness |
11-05-2017, 10:59 AM | #33 |
Dyno Show Queen LOL
Here ya go..
New Fascia (so no cutting) 2 bezels L R 2 dive planes L R 1 splitter 2 end winglets for splitter 6 inserts that go into splitter 6 screws that hold winglets to splitter 14 clips that hold dive planes to fender and bezels and 2 that hold top part of winglets to fascia totally 16 All other parts tabs clips ect reuse.. Optional.. Upper grill Lower grill Area of concern Ground effects will be mosiac blk paint splitter to match or paint ground effects and splotter flat blk
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 11-05-2017 at 11:10 AM. |
11-05-2017, 11:12 AM | #34 |
Here is the diagram I'm going off of to order everything except the fenders, which I don't have that that particular diagram. The other issue I have is, I'm not certain which codes or "usage" applies to only the 1LE but not my ZL1.
11-05-2017, 12:42 PM | #35 | |
I have a few questions if you don't mind; So yours is a ZL1 and you've done this exact mod? Also, I've been told that my ZL1 Fenders won't work. Did you replace the Fenders as well? If not, are they the same part number as the 1LE do you know? When you say, "6 inserts that go into the splitter", what part number are you referring to so I can order the correct ones. Also part number for the 16 clips for the dive planes. Thanks in advance! |
11-05-2017, 02:34 PM | #36 |
Dyno Show Queen LOL
Zl1 fenders work just fine.
Number 26.. they call nuts
11-05-2017, 06:11 PM | #37 |
02-23-2018, 09:44 AM | #38 | |
Drives: Mosaic black 2SS Join Date: Jul 2016
Fitment? I’m interested in adding a ZL1-1LE Splitter to my build however I want to make sure it will fit. |
02-23-2018, 09:25 PM | #39 |
Drives: Nothing cool atm Join Date: Aug 2017
It's a mass produced car. It's a camaro. The only people who will actually notice are the people who know the camaro. And those are the people who will be able to tell that it's not a ZL1. Everyone else will just see another camaro. Get over it
02-23-2018, 09:26 PM | #40 |
Cars in this thread look great! Good job
02-24-2018, 06:50 PM | #41 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
All I want are the fenders. Will the ZL1 fenders fit with the SS/1LE bumper/hood?
11-07-2018, 07:24 PM | #42 |
Instagram: @SSAVAGEVERT
Drives: 2016 SS M6 Vert Join Date: Jan 2016
What is that duct inside of the vent?
More pictures to come when it's not overcast out![/QUOTE]
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build |
