09-08-2017, 06:51 AM | #1 |
Drives: 2002 Pontiac T/Am, 2016 Camaro 2SS Join Date: Mar 2016
2016 SS with ZL1 1LE Front End - Build Log
Hey everybody! I posted my car on the Camaro 6th Gen FB group and thought I'd follow up here for people to learn what I did.
I own a Camaro SS and have modified the car with ZL1 1LE front end parts. In terms of "big name" parts this included the fascia, fenders, aero. Abez has his own thread with the PN's but: Front Fascia (A1Z) 84280755 (84177343 old) Fender 84291360 (84157562 old) Fender 84291359 (84157561 old) Grille (A1Z - upper) 84277490 Grille (A1Z - lower) 84222508 Hood (I skipped for now) 23483328 Hood Scoop (I skipped for now) 84335785 Front Splitter (A1Z) 84177344 Deflector PKG (OTR AIR) Dive plane 23329726 (LH) 23329727 (RH) Bezels for Fog/Dive 84277492 (LH) 84277493 (RH) Rocker Panels (I skipped for now) 84177431 (LH) 84177432 (RH) A few learnings: 1. The impact bar is the same between cars, but the shroud and foam that go over it is not to my understanding. The cover has attachment points to the fascia that do not match up if you leave the SS part. 2. Be careful with splitters and grilles - I ordered the ZL1 splitter which was 100% incorrect and had to get another. 3. The SS hood does not fit perfectly - but it's damn close. The feature lines are a little off but the more problematic area is the curvature of the hood itself. The SS hood is more sharp and angular around the "bend" where the ZL1/ZL1 1LE hood is more gradual. -Interesting question: The AndersonComp CF ZL1-style hood is made for SS fitment but I have seen a few ZL1 1LE's on Instagram with it (check AC insta account). So I'm not sure if they have another fitment that works for these cars or what. Even their reps couldn't officially confirm. 4. Of course you will need wider front tires on anything below an SS 1LE. Right now I am rocking some 285/40/19 Apex ARC-8's. Great customer support from them. Love the wheels. 5. The "ZL1" badge on the lower grille is a part of the grille itself. I had no intention of badging my car that way but it was included so I'll have to find some way to file it off and refinish that section. Just another heads up. You'll also not be able to use a black or illuminated bowtie if you have one since the upper grille has the flowtie included. 6. The swap cost about $5000 with labor and paint, not counting wheels/tires. I would say you could the parts cheaper than I did and do everything for about $4000... but that depends how important the hood/rear spoiler/etc is to you. I'll be getting a new spoiler soon but probably not the ZL1 1LE style. More pictures to come when it's not overcast out! |
09-08-2017, 08:14 AM | #2 |
Drives: S10 Join Date: Apr 2017
That is looking good, love the front end of the ZL1 1LE
09-08-2017, 09:31 AM | #3 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Fascinating to read and see how the hoods are actually different, albeit subtle.
Thank you for you sharing!
09-08-2017, 11:07 AM | #4 |
Drives: 2017 Camaro SS NGM, 2015 Murano Plt Join Date: Apr 2016
It`s looking good!
09-08-2017, 11:14 AM | #5 |
Drives: SS-6-SPD Join Date: Jan 2017
great info!! saw your post on fb..
how much did everything run you? |
09-08-2017, 11:27 AM | #6 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
The head lights are fitting in the ZL1 fascia. 1:1 what kind of et are you using.?
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
09-08-2017, 11:35 AM | #7 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
I like it! Let us know how you get rid of the ZL1 badge when you do.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
09-08-2017, 11:45 AM | #8 |
09-08-2017, 12:02 PM | #9 |
Drives: 2016 1SS Join Date: Jun 2017
I love the new look bro!
I was actually thinking of making mine a ZL1/1LE before I decided to go straight ZL1. I think I still can all I would need is the dive planes and the lower grille and splitter right? Which sort of lead me to this question; the ZL1 1LE lower grille can only match up to the ZL1 1LE splitter? Also I'm assuming the ZL1 front fascia is the same? Thanks! |
09-08-2017, 01:57 PM | #10 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Saw it on FB love it awesome job and thanks for the info.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
09-08-2017, 05:31 PM | #11 |
Drives: SS 1LE Join Date: Aug 2017
I've heard talk that the ZL1 1LE fenders are the same as stock Camaro ones, they just use spacers. Does anyone know if this is true?
2018 SS 1LE
09-08-2017, 05:40 PM | #12 |
09-11-2017, 07:50 PM | #13 |
Slow_V8
Drives: 16 white 2ss Join Date: Jul 2017
2016 white 2ss, stainless work exhaust system and K/N CA
09-12-2017, 06:26 AM | #14 |
BYND GARAGE
Drives: 17' 1LT Turbo Join Date: Feb 2016
So doing this will allow the zl1 hood to fit the car? Since it doesn't fit stock ss and lt models?
