08-03-2017, 05:08 AM | #1 |
Drives: 2012 Camaro Lt Join Date: Jul 2017
Transmission Fluid Change??
I have a 2012 Camaro Lt (V6 Manual).
@ How many miles should the Transmission Fluid be changed? I looked in the service manual but nothing specifically stated that i should be changed @ so and so miles. I did see chevy's site that said @ 45,000 miles on an automatic transmission. But didn't say if that applies to a manual transmission. Any ideas? Also what's the difference between changing the transmission fluid and flushing it? isn't flushing also changing the transmission fluid? |
08-04-2017, 02:41 PM | #2 |
Bump! - any ideas guys :(
08-04-2017, 02:51 PM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
It's super easy to do, and it doesn't hold much. I do it every 3 years or 30,000 miles.
Same fluid goes into the DIFF too, so I would do that at the same time and use the same interval.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
08-04-2017, 10:19 PM | #4 | ||
Also what's the difference between a transmission fluid change and a flush? Would this be the correct steps? |
08-07-2017, 09:47 AM | #5 | ||
A fluid change is just a drain and refill like you just saw. A flush is when a transmission is hooked up to a machine, where they flush fluid in one direction and out the other with more force than just gravity. A flush isn't necessary if you keep up with the routine fluid changes. Just like how you don't need to flush an engine, just gravity change the oil. If you buy 3 quarts of gear oil, and a fluid pump, you can get the trans and diff done in an hour or so. I bought 3 quarts of this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I used this pump (but it didn't fit the quart bottle very well): https://www.amazon.com/Plews-55001-L...P6A6PXV40CPE02 And I added this GM fluid to the diff: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ~2 quarts for the trans, and ~1 quart for the diff.
08-07-2017, 02:46 PM | #6 |
@ChibiBlackSheep
I see. Thanks man you've been a lot of help! |
08-07-2017, 03:04 PM | #7 |
Glad I could help!
08-07-2017, 04:38 PM | #8 |
08-07-2017, 08:16 PM | #9 |
Drives: 2011 Camaro LS Join Date: Apr 2017
Manual says 1 quart plus the 2.5oz of friction modifier
08-07-2017, 09:02 PM | #10 |
Drives: 2012 IBM 2SS/RS LS3/M6 Join Date: Apr 2015
I did mine recently and used Royal Purple:
https://www.amazon.com/Royal-Purple-...dp/B001DKTG0G/ It's expensive and I thought I may have been buying some snake oil, but I can definitely tell a difference. Much smoother especially 1st to 2nd at high rpm's.
Stainless Power LT Headers, K&N Typhoon CAI, VMAX Ported Throttle Body, Jannetty Tune, Phastek Scoop & Washer Bottle Relocator, VTC
Resonator Delete w/Flowmaster Super 10's, BMR Lowering Springs, Koni Orange Struts, Factory Hurst Short Throw Shifter, Skip Shift Eliminator, DRL & Halo Harness, Window Valet Scosche Kit w/Pioneer AVH-4100NEX, Lloyds Custom Mats, Blue LED Footwell Lighting |
08-08-2017, 11:00 AM | #11 | ||
You will be amazed at how dirty the original fluid is, and how much metal is on the magnets.
08-08-2017, 11:21 AM | #12 |
Drives: '13 LS, '09 Forester, '11 HD SGlide Join Date: Jul 2017
Going to have to check those videos out. If it's not hard to do.....
2013 Chevrolet Camaro LS - M6
2011 Harley Davidson Street Glide 2009 Subaru Forester - M5 |
08-08-2017, 02:00 PM | #13 |
It really isn't! If you are comfortable enough doing an oil change, you can change the trans and diff fluid on these cars.
08-08-2017, 02:31 PM | #14 | |
Tags |
camaro, fluid, manual, transmission |
