08-15-2023, 01:27 PM | #1 |
Drives: 2023 2LT RS Join Date: Apr 2015
Neutral
Is there a way to put the car in neutral without firing up the motor? This is for 2023 a10s. Thanks!
08-15-2023, 01:46 PM | #2 |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
Have you tried to hold the start button without having your foot on the brake? It puts the car into a mode as if it were running so you can work on it or make feature adjustments.
Might let you do it with the parking brake on and putting your foot on the brake.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
08-15-2023, 01:48 PM | #3 |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
Foot OFF the brake, push and hold ignition button until your accessories turn on. Foot on brake, shift to N. Try that. I believe that's how I did that on my car yesterday.
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
08-15-2023, 02:15 PM | #4 |
Push and hold for about 5 seconds and foot off the brake worked!
Thank you! |
