10-23-2017, 11:10 PM | #85 |
Anybody running 35mm Offset on the front?? Would love to know how far it sticks out...so I can say yes or no to a set of wheels
10-24-2017, 12:12 AM | #86 |
Drives: SS-6-SPD Join Date: Jan 2017
How wide is the wheel ? If it’s 20x10 +35 .. it won’t work .. unless you are planning on running a 265 or smaller tire .. ( which will be a stretch .. not a good look )
10-24-2017, 12:23 AM | #87 | |
w/ 245/45R19 Last edited by DarkFangz1100; 10-24-2017 at 12:47 AM. |
10-24-2017, 09:48 AM | #88 |
seems like that would be fine .. but why such weak specs?
Suspension clearance: Package 2 is 10 mm (0.4'') closer to suspension/brakes components. Acceptable for most cars. Fenders clearance: 100% clear (leaves even more room than OEM) Wheelwells clearance: The same. SPEEDOMETER: The same. |
10-24-2017, 01:23 PM | #89 | |
Going off what tirerack recommended since they are "Sponsored" |
10-24-2017, 02:14 PM | #90 |
10-31-2017, 11:14 AM | #91 |
Drives: 2021 ZL1 6MT Join Date: Jan 2017
That's what I did...
10-31-2017, 12:35 PM | #92 |
Drives: 2015 Ultimate Track SS Join Date: Apr 2015
For what its worth, 1LE fronts are actually +20, not +23. The +23 number is left over from Gen 5 cars. For most, that 3mm won't matter. It only becomes an issue at aggressive negative camber numbers.
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/ 2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD 2010 2SS/RS M6 -- SOLD |
11-01-2017, 11:16 AM | #93 |
Drives: 2017 1le Join Date: Mar 2017
19" wheels I've ordered
Heres a pic of the 19" forged wheels i've got on order.
19x10+20 / 19x11+43 OEM fitment for my 1LE. I'll post images once I have the tires and wheels on. |
11-06-2017, 03:36 PM | #94 |
Drives: camaro Join Date: Nov 2011
Warehouse fun with M017
Just having a little fun with our M017 flow forged wheels, Borrowed these Long Spike lug nuts and slap them on to see what it would look like.
so what do you guys think yay? or Nay? |
11-10-2017, 01:47 AM | #95 |
Drives: 17 SS Join Date: Jul 2017
I am a noob when it comes to tires / wheels. I'm looking to get a set of aftermarket wheels for my 2SS. I want to use my stock tires as they have plenty of life.
Stock Setup: Front 20 X 8.5 (Tire: 245/40/R20) (Offset: 25mm) Rear 20 X 9.5 (Tire: 275/35/R20) (Offset: 39mm) Aftermarket Wheels: Front 20 x 9 (Offset: 35mm) Rear 20 x 10 (Offset: 40mm) Will the aftermarket wheels fit my car and current tires? Thanks in advance. |
11-10-2017, 10:16 AM | #96 | |
yes...
11-10-2017, 03:03 PM | #97 |
11-10-2017, 03:28 PM | #98 |
The rear without any doubt 0 issues ... the front shouldn’t be any issue as it’s 10mm less but it’s .50” wider ( which is 12.70mm ) so in sense it’s goijg to have oem fitment .. I personally if going aftermarket wheels would go more aggressive than stock ..
