02-24-2020, 08:52 PM | #1 |
Drives: 2019 1LE/ss 2014 ss/rs summit white Join Date: May 2016
Pinned lt1 crank for Procharger
This week everything i order for my build comes in. Trying to figure out if the ati super dampener requires the crank to be pinned or not.
Going with the upgraded 8.25 pulley on prochargers side. Reading the install for the super dampener says going superchager it requires you to pin the crank seeing if anyone has had to do that or if its done already or not required. Also does crank bolt p/n 11547372 work? Thanks everyone. |
02-25-2020, 06:31 AM | #2 |
We've never pinned the crank on an Lt1 as it has keyways in the snout of the crank. We always us the GM replacement LT1 crank bolt. It was required on the LS motors but not aware of anyone pinning the LT1 motors.
02-25-2020, 09:59 AM | #3 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
you'll get a modified stock crank bolt from procharger so don't go around and buy one as it won't be long enough. I stuck with the stock balancer just because so i didn't pin my crank, people have and people haven't done it. either way you'll be fine, if you plan on doing the install yourself just know procharger doesn't send all the bolts you need and skip over a bit on info you'll need.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
02-25-2020, 10:12 AM | #4 |
I have seen LT motors needing the crank pinned on higher horsepower builds because the factory key sheared off. Mainly bigger blower stuff like the F1a-94 or larger. Look up Stangkilr C7 on youtube.
2016 NFG 1SS A8
02-25-2020, 12:40 PM | #5 |
thank you for that and just looked at the bolts and the oem bolt head is to wide for the hub. but the oem ls1 crank bolt fits just right the heads smaller to fit in the hub and the shank, threads are the same thank god .
02-25-2020, 12:41 PM | #6 |
thank you for that and i will. also thats why i asked cause ive seen that also.
02-25-2020, 12:43 PM | #7 | |
Tags |
8.25, ati, crank, pin, procharger |
