Old 03-23-2019, 11:00 AM   #1
ac-427
Drives: 2018 Camaro 2SS Redline Convertible
Fastech Color Matched Cover Install
I just installed the Fastech aluminum cover kit in white on my Redline SS Vert. The match to the car's Olympic White by the powder coated covers was good enough that any color difference was not apparent. I deviated from the Fastech instructions by using adhesive Velcro rather than the supplied double stick so I could remove the covers without any problems. I did use the adhesive foam supplied by Fastech to eliminate rattles. I've attached photos illustrating the installed covers and Velcro placement. Also, you might notice the Chevy performance emblem on the center cover. I used a heat gun and a plastic tool to remove the emblem from the original sheet metal and then attached it with double stick tape. My SS is a daily driver that I also show, so the white panels not only look good, but are much easier to clean than the original sheet metal that often held water spots.
2019 Buick TourX
2017 Colorado Redline
1966 Ford Mustang Pro Touring
ac-427 is offline   Reply With Quote
Old 03-23-2019, 11:10 AM   #2
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Originally Posted by ac-427 View Post
I just installed the Fastech aluminum cover kit in white on my Redline SS Vert. The match to the car's Olympic White by the powder coated covers was good enough that any color difference was not apparent. I deviated from the Fastech instructions by using adhesive Velcro rather than the supplied double stick so I could remove the covers without any problems. I did use the adhesive foam supplied by Fastech to eliminate rattles. I attached photos illustrating the installed covers and Velcro placement. My SS is a daily driver that I also show, so the white panels no only look good, but are much easier to clean than the original sheet metal that often held water spots.
That looks great! Well done man!
ssmike is offline   Reply With Quote
Old 03-23-2019, 05:34 PM   #3
ac-427
Thanks Mike!
2019 Buick TourX
Old 03-23-2019, 08:29 PM   #4
Fatty1707
Drives: 2019 ZL1 A10
Good looking unit
Fatty1707 is offline   Reply With Quote
Old 03-24-2019, 12:01 PM   #5
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
how much
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned
biker2k is offline   Reply With Quote
Old 03-25-2019, 04:59 AM   #6
ac-427
Originally Posted by biker2k View Post
how much
I got them for $99 plus $20 for white powder coat with free shipping.
2019 Buick TourX
Old 03-25-2019, 06:28 AM   #7
grampa_ss
grampa_ss's Avatar
Can you please post the link to where you purchased these?
Old 03-25-2019, 11:43 AM   #8
ac-427
Here ya go: https://www.phastekperformance.com/2...lates-63up.htm
2019 Buick TourX
