02-27-2019, 12:04 AM | #1 |
BYND GARAGE
Drives: 17' 1LT Turbo Join Date: Feb 2016
1LE OR SS???
Been tossing around the idea of trading my car in for a 1le but I also want to add upgrades to the car suspension wise. Detroit speed coilovers, upgraded sways and brake lines etc so would it be a waste to get a 1le and swap out those companies?? Or could the 1le be a good starter car to begin the build with?
02-27-2019, 12:09 AM | #2 |
BYND GARAGE
Wheels and tires too
02-27-2019, 05:41 AM | #3 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Buy a 1le and use your xtra money for track days and expenses..ie tires and brakes. In stock form it will hang with almost any car you will encounter...provided you do your part.
2017 1LE Hyper Blue
02-27-2019, 05:56 AM | #4 |
Drives: 2018 SS Join Date: Jun 2018
So the question is should you buy an SS with the 1LE package, and then remove the 1LE package? This thread makes zero sense. I mean if you have nothing better to do, and money to burn, go for it.
02-27-2019, 06:43 AM | #5 |
Drives: 2018 2ss 1le Join Date: Jan 2018
not sure why you would buy a 1le and before ever driving it plan on suspension upgrades...
def buy one but leave suspension alone... like said , save money for tires and such...
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
02-27-2019, 06:52 AM | #6 |
Drives: 2018 1SS Join Date: Dec 2018
There aren't many upgrades I'd do without driving it first - echoing what the others have said. One thing you could plan pretty quick is the solid rear cradle bushings as that is a no-brainer for most track folks, along with the tires/brakes suggested by others. Besides that, the driver upgrade is the best modification to make - track time.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
02-27-2019, 06:59 AM | #7 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
Well, there are a lot of reasons why someone would want what the Detroit Speed coilovers have to offer. If they have spent time tuning a racecars suspension they absolutely will want the flexibility in camber adjustments, spring options, and compression and rebound adjustments. Without full access and the ability to fine tune the PTM and E Diff I would stay with the more analog SS for this type of work. There are also better (and more expensive) brake options for the car as well so the OP could save some money if those are the parts he is looking at.
02-27-2019, 07:27 AM | #8 |
Drives: 17 SW 1LE Join Date: Jun 2017
To answer your question we really need to know what you use you car for...
Drag? HPDE/track days? street only? |
02-27-2019, 09:27 AM | #9 | |
Drives: SS 1LE Join Date: Oct 2017
02-27-2019, 09:37 AM | #10 |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
I'm not sure what is actually being asked in this post. But I will say this. The stock suspension on the SS 1LE will probably out perform any pieces you might add. Additionally, with the coilovers you lose the easy ability to go from track to touring.
Buy an SS 1LE and leave it alone.
2018 1SS 1LE
02-27-2019, 11:31 AM | #11 |
i got a ss instead of a 1le because 1. it wasnt out yet 2. i knew i was going to modify a bunch of stuff but i still wish i got a 1le just for the seats and brakes lol but hey you do you !
02-27-2019, 12:42 PM | #12 |
Drives: 2018 SS 1LE Join Date: Sep 2018
The 1LE package is worth every single penny. ELSD, Mag Ride, Recaro Seats, Wheels/Tires, 1LE suspension components, those are the major things in the 1LE. There are other stuff that comes with it too. Can’t get all of that for $7k if you get a non-1LE.
02-27-2019, 01:45 PM | #13 |
Drives: 2018 SS 1LE Join Date: May 2018
To me the only reason to avoid the 1LE is if you want an auto. If manual is the gig the 1LE package is worth every penny!
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
02-27-2019, 01:49 PM | #14 |
BYND GARAGE
Thank you all for your input! I’ve made my decision and I’m ganna go with a 1le and improve on that platform if needed. 2019 Shock 1LE
