Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 02-08-2017, 05:41 PM   #1
frenchsquared
frenchsquared's Avatar
Drives: 15 Z28, 01 Corvette, 96 Corvette
Installing factory sub?
You would think GM would include instructions but not so much. Power and ground are pretty self explanatory. But thats about it. Where does the green and brown wire plug in?
If I have to take the entire interior out of the car I think I will return it and install real stuff. I thought this was a simple plug and play.
How do you Locate position 40 and 32 on the radio connecter and install one of the blue self stripping connecter onto the wire.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
frenchsquared is offline   Reply With Quote
Old 02-09-2017, 08:50 AM   #2
frenchsquared
I called crutchfield and they told me 40 is the tan and 32 is the grey. They also gave me a diagram. This is not at all plug an play. Im not happy about having to splice into the wires.
Should have just gone aftermarket.
Old 02-10-2017, 02:47 PM   #3
iownedu
Drives: 2014 Camaro Z/28
Radio Shack sells some quality T-taps for doing that. So you don't have to cut or solder your factory wiring, they are not the shitty 3m ones from Walmart.
2014 Camaro Z/28. Last Pre-Production car, #69. White without A/C, 1 of 4.
2008 Mercedes AMG C63
Longtubes, Intakes, Wheels, Coilovers, Tune
2006 Lamborghini Gallardo SE
Gated Verde Ithaca
Heffner 1000TTG
iownedu is offline   Reply With Quote
Old 02-10-2017, 02:48 PM   #4
iownedu
https://www.radioshack.com/products/...e-con-18-22awg
Gated Verde Ithaca
Heffner 1000TTG
Old 02-11-2017, 12:44 AM   #5
hjdca
Drives: 2015 Z/28 Black
I have been thinking of installing that sub... Let us know how it works out. Thanks !!
2015 Black Z/28
70 Chevelle SS396
01 M3, 88 Land Cruiser
hjdca is offline   Reply With Quote
Old 02-11-2017, 11:11 AM   #6
rh96ss
Drives: 2013 ZL1 Convertible/2015 Z/28
Curious, what part number are you installing?
rh96ss is offline   Reply With Quote
Old 02-11-2017, 12:50 PM   #7
frenchsquared
Part Number: 19303112
There are no instruction if you buy it from gm. At first this makes it rather confusing since its not plug and play. You just need cut the end off the amp plug and tie into the rear speaker. I followed Crutchfields instructions and ran the wire all the way to the deck and sliced into the front speaker. I would not do it that way again. I would just tap into the rear speaker. I have these instructions if anyone wants them. I had to call to get them.
I used some cheap splice connectors from the local part store. I did not know these were needed and I wanted my car back together. I thought this kit was plug and play. Its only that way if you have the Boston acoustics system. Our Z28's do not. I do not feel they will be an issue. I am changing to a mylink system soon so I can change them out if needed.
I think if I were to do this again I would get a 5 channel amp, a JL sub and all new door speakers and just run everything aftermarket.
I love the look. Its very easy to unbolt and totally looks factory. For $580 I am content. The miss understanding wasn't a big deal after all. It was just an unhappy surprise.
Im very impressed with the sound for something basically from GM. The bass is nice enough that I want to turn it up and the front speakers wont take it. Im going to have to upgrade the or keep the volume down. Its in no way a pounding system but that isn't what I wanted. I just wanted a little more bass and something that looked factory.
I coated the trunk in Dynomat at the same time. This is a must have. The car is much quieter and much nicer on road trips. I know, I know... I added a hole 3 lbs and killed GM's weight loss idea. Its my car and I enjoy driving it more.
I have a rear floor mat with the Z28 logo. I had to cut a small hole in this for the rubber mount the sub sits on. Its completely covered by the sub... so I guess its not big deal. I think without the dynomat and this floor mat the sub would rattle around. Without the carpet kit its kinda loose. So beware of that if your trunk is empty.
I would buy this sub again in a second if I had the Boston Acoustics system. The sound quality and easy of install in that set up would be great.
Old 02-13-2017, 10:04 AM   #8
Dustin.N
Drives: 2014 1SS/1LE
Here are the instructions.
http://www.kicker.com/app/manuals/vs...2020151028.pdf
Dustin.N is offline   Reply With Quote
Old 02-13-2017, 11:37 AM   #9
frenchsquared
Originally Posted by Dustin.N View Post
Notice those dont tell you were pin 32 and 40 are?
Connect the six inch adapter harness to the end of the two pin connecter. Locate position 40 and 32 on the radio connecter and install one of the blue self stripping connecter onto the wire. Those blue self stripping connecters are also not included if you get from GM.
Old 02-14-2017, 08:59 AM   #10
hjdca
I think I will order the sub... You are saying that I do not have to run the wire from the dash ? I can just tap into the wires in the trunk to do the whole installation ? That sounds cool... How do I do that again ? Thanks !!
2015 Black Z/28
70 Chevelle SS396
Old 04-19-2017, 11:34 AM   #11
hjdca
Im very impressed with the sound for something basically from GM. The bass is nice enough that I want to turn it up and the front speakers wont take it. Im going to have to upgrade the or keep the volume down. Its in no way a pounding system but that isn't what I wanted. I just wanted a little more bass and something that looked factory..............
Hello, I finally got around to ordering this factory subwoofer. I did some research and I think I can improve the volume situation you mention above by using the JL Audio CL-RLC Remote Level Control. It is another $50 or so, but, this controller should allow me to connect the sub to the rear driver's speaker, and get a really clean signal, plus manage the signal boost (+ or -) for optimum volume... It seems to be a super easy install, I will just use double sided tape to stick the small components on the underside of the rear deck. I will let you know how it works out..
2015 Black Z/28
70 Chevelle SS396
Old 04-20-2017, 10:54 AM   #12
frenchsquared
Please let me know... I would love a bass control.
Old 03-11-2019, 11:24 PM   #13
Rocky1974
Rocky1974's Avatar
Drives: 2010 RJT 2SS M6 Camaro
I have the Kicker, which I thought was the same as the GM. I have Boston Acoustics and mine was NOT plug n play. I had to tap into the LH rear speaker, but I did not have to cut the end off of the cable. Mine came with a short cable and t-taps to make the connection. Kicker sells two versions. I think the one that they sell for the non-BA systems may be plug n play, but it comes with an amp that you install under the dash. That install requires you to remove the head unit. The instructions for both versions are available on Kicker's website. I downloaded and printed them.
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
Rocky1974 is offline   Reply With Quote
Old 03-12-2019, 09:42 AM   #14
hjdca
Yes, you are correct. I have the stock Z/28 stereo and if you just buy the subwoofer, you have to tap into the rear speakers, and yes, you can still do this without cutting. If you buy both the subwoofer and the amp, then, the wiring harnesses are all plug and play. You plug into the back of the head unit, the back of the new amp, and the subwoofer with the supplied wiring harnesses. I tried both and the system sounds way better with the amp and subwoofer together. The components are tuned for that.
2015 Black Z/28
70 Chevelle SS396
