08-03-2023, 07:19 PM | #1 |
Drives: 22 Convertible V8 LT1 Join Date: Feb 2019
Rear Bumper Lower Fascia Bracket Broken
The noise from this has been driving me mad so I finnally got underneath the car to investigate. It appears the supporting brackets are both broken and totally loose. I attached a photograph. Although my car is still under 36k, I did get rear-ended and had insurance work done less than a year ago and I have since relocated. That fiasco was crazy as I was hit by another Camaro driver! Went without my car for a month due to State farm. Would a local dealership see this as warranty work? Upon further research it appears the bracket is its own part #23281500. Perhaps I can DIY. My bumper cover is also misaligned and sagging similar to the 2017 GM bulletin…frustrating
https://www.tascaparts.com/oem-parts...acket-23281500 https://www.tascaparts.com/oem-parts...ascia-84054988
I bought my first 6-Speed convertible Camaro in November 2018 and now drive a Hot Red V8 LT1 M6.
My Windows Sticker: https://cws.gm.com/vs-cws/vehshop/v2...FE3D78N0129849 |
08-03-2023, 07:34 PM | #2 |
If the Carfax report shows it was rear ended I don’t think it will be warranty, although you never know if the dealership would try to run it through a warranty claim also that part number comes up as being $14 so you might want to just change it yourself
08-03-2023, 08:44 PM | #3 |
Long hauler
My 1LT had a broken one of those, from what I figured it just adds rigidity to the lower valence. It’s two bolts (one to the rear crash bar, one to the bottom of the lower valence) easily accessible as you’ve already gotten to the ‘harder’ to reach of the two in your photo
08-04-2023, 07:09 AM | #4 |
Hot Camaro
You call your insurance company and tell them that you just learned that the work that was done was not done completely / properly and you want to file a supplemental claim. See where that goes...
08-04-2023, 12:57 PM | #5 | |
I would but the accident occurred in the state of Kentucky and there the claim was processed through the at fault drivers insurance. The body shop did say they warranty their work and to come back if I have any issues but that does involve a road trip. Never a bad excuse to drive the tail of the dragon again!
08-04-2023, 01:24 PM | #6 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
For $30 I would probably just do it myself. You’d have a hell of a lot more than that in time dealing with it all. My 2c.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
08-04-2023, 01:39 PM | #7 | |
Hot Camaro
08-24-2023, 02:53 PM | #8 |
I ordered the part and will install it myself. Can’t be any harder than replacing the door check.
https://www.ebay.com/itm/295539726242
08-26-2023, 10:02 AM | #9 |
Turns out it is more involved than I imagined. The repair shop installed the bumper cover first and then decided to be lazy and install these brackets backwards. To install them properly, the bumper cover needs to be removed. I will share a photos next time I find myself underneath the car.
08-26-2023, 02:53 PM | #10 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
That's annoying. At least it's not something worse though, and is straightforward.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
08-26-2023, 04:40 PM | #11 |
