04-19-2023, 02:08 PM | #1 |
Drives: 2023 ZL1 M6 Sharkskin Join Date: Nov 2020
Brand new 2023 ZL1 low power
Hi guys, I’m not totally sure I have a problem yet so this might be getting a little ahead of things… I recently bought a new 2023 ZL1, it’s only has 150 miles on it. Anyhow it doesn’t seem to have the power of my 2020 ZL1, it honestly feels a little more like my 2022 SS-1LE Camaro. I haven’t taken it over 4000 RPM’s until I get to at least the 500 mile break-in. Maybe it will feel better after I can drive it harder. I also remember my other ZL1 and SS-1LE would get a lot of black soot in the exhaust tips after only a few miles. After 150 miles this new ZL1 has no soot but does have some rusty looking corrosion on the inboard tip… Any thoughts??? Thanks!!
Also, If I remember correctly my supercharger gauge on my dash was reading something like NEGATIVE 10-15 PSI while I was just cruising on the highway, is that normal? And what should my max POSITIVE PSI be when accelerating?
2019 Porsche 911-T M6-SOLD
2020 Crush ZLE A10-SOLD 2023 Red Hot ZLE M6 ordered 5/9/23, never built 2022 Shadow Grey 1SS-1LE M6-SOLD 2023 Sharkskin regular ZL1 M6-SOLD Last edited by Greg83; 04-19-2023 at 06:59 PM. |
04-19-2023, 02:16 PM | #2 | |
For reference if the system has air in it, then it the intercooler pump will shut down causing temps to rise and for the call to pull timing because the manifold air temps are too high |
04-19-2023, 02:34 PM | #3 | |
2020 Crush ZLE A10-SOLD 2023 Red Hot ZLE M6 ordered 5/9/23, never built 2022 Shadow Grey 1SS-1LE M6-SOLD 2023 Sharkskin regular ZL1 M6-SOLD |
04-19-2023, 02:41 PM | #4 |
Drives: Cadillac Cts-V Wagon Join Date: Feb 2012
I believe the LT4 in the ZL1 and CT5-V Blackwing has programming in the ECU to limit power until you reach 500 miles. The mild corrosion could be a result of the vehicle having some type of constraint and thereby stored at the assembly plant (basically a cold start that has moisture in the tips and then just sits until the constrained item is back in stock).The DI runs cleaner than a standard port injection car and since power is limited you aren't tipping into power enrichment mode where a lack of wideband sensors would potentially cause soot.
04-19-2023, 03:17 PM | #5 | |
04-19-2023, 04:41 PM | #6 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Yes, this can happen on a new vehicle. When the 5th gen ZL1 came out, there were cars that had 0 supercharger coolant in them.
I'd do as mentioned with the bleeding but I would also wait until you break the engine in and car actually feel the power band to see how it really feels. Quote:
04-19-2023, 05:27 PM | #7 |
Drives: Chevy Camaro ZL1 Join Date: Feb 2023
Burp the IC system. Thats is.
04-19-2023, 05:28 PM | #8 |
The above comments are all great suggestions, there also have been several people that have found the factory or dealer only put in 91 or poor quality gas that severely messed with the fuel trims. If you have good quality 93 in your area get a full tank and pull the battery negative cable for a bit to reset the ECU fuel trims.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
04-19-2023, 05:42 PM | #9 | |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
04-19-2023, 06:02 PM | #10 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
Some misinformation in these responses. First, the ZL1 doesn’t limit power below 500 miles. 2nd, the comment about “being in the power band” is inaccurate as well. The LT4 makes peak torque below 4K rpm, and in a given gear, THAT is what you feel. So it should feel strong at 3500 rpm in 3rd gear, for example. In 3rd gear the car pulls harder at 3600-4000 rpm than it does at 6000 rpm. So if it feels like an SS, something isn’t right. I second (or third?) the s/c coolant air bleed. It’s pretty easy to do on your own and can be done at home, and you don’t need a custom tool like some will claim. Or you could risk it at the dealer. Make sure the engine coolant reservoir is full as well.
3rd: the LT4 runs fine on 91, not ideal, but it still makes a lot of torque. That’s all there is in a huge part of the country.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 Last edited by Idaho2018GTPremium; 04-21-2023 at 11:07 AM. |
04-19-2023, 06:35 PM | #11 |
Thanks for all the great advice guys!!! I’m trying to run this tank low and then I will fill with 93. I will definitely look into bleeding the super charger. Worst case I’ll have the dealer look at it when it goes in for its first free oil change. I know… I don’t like them changing my oil either, and I usually do it myself but a free oil change is always nice, and they can look into my problem too. I also understand they are basically parts replacers and can often only fix things if a code shows up.
04-19-2023, 06:58 PM | #12 |
Hey guys, I just added this to my initial post… If I remember correctly my supercharger gauge was reading something like NEGATIVE 10-15 PSI while I was cruising down the highway, is that normal? And what should my max positive PSI be when accelerating?
04-19-2023, 07:09 PM | #13 | |
Bleeding the intercooler circuit is a no brainer, make sure you get it done, as others already stated above. Unfortunately GM did not add a supercharger coolant tank from the factory, so you're at the mercy of whoever assembled the engine and filled the fluids to have done it properly, the only way you as an owner could check is opening up the S/C coolant loop. I'd say let the dealer do it under warranty, and you make sure they know what they're doing, don't hesitate to go to a different service department if you see anything suspicious.
04-19-2023, 07:14 PM | #14 |
arpad_m hit the head on the nail, LT4 blower has a vacuum bypass on the blower that is open at idle and cruising as soon as you lean into the blower creates boost closing the bypass and allowing boost to ramp up. Max boost I see is 9-10 maybe 11 PSI depending how dense the air is but that's based on the rather simple gauge.
