10-12-2019, 05:34 PM | #1 |
Drives: 2019 Chevrolet Camaro ZL1 1LE Join Date: Sep 2019
Will standard ZL1 wheels fit on ZL1 1LE?
Hey guys, wanting to get a second set of wheels and tires for the ZLE. Will stock 20” ZL1 wheels and tires fit? It seems I can buy a set of OEM wheels and good condition tires for near what a new set of PS4 will cost! TIA!!
Check out my YouTube to see the ZL1 shenanigans!
https://www.youtube.com/channel/UCkm...3OKTzDGIAkqYxQ |
10-12-2019, 05:44 PM | #2 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
They will fit without any issues.
10-12-2019, 05:51 PM | #3 |
Sarcasm loading --------
Standard ZL1 tires are .5" taller - your fender gap will be 1/4" smaller than it already is; but you will also gain some ground clearance.
Standard ZL1 rear - 305/30R20 = 27.2" height ZL1 1LE rear - 325/30/R19 = 26.7" height
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
10-12-2019, 09:40 PM | #4 |
True, but keep in mind the ground clearance will only be .25” higher.
10-13-2019, 11:35 AM | #5 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Im running 355/30R19's on the rear of my ZLE and at 27.4in tall I have no issues
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
10-15-2019, 09:44 AM | #6 |
Won’t the speedometer be off if you go to 20s instead of the stock size 19s? Just something to think about.
10-15-2019, 10:49 AM | #7 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
They are available cheap because they are such a biotch to clean, lol.
10-15-2019, 11:53 AM | #8 |
I agree with that statement CW!!!
10-15-2019, 09:30 PM | #9 |
Thanks guys!! They do look ridiculous to clean hahaha
10-25-2019, 08:20 PM | #10 |
Does the slight difference in sizing affect speedometer or any sensors or nannies?
10-26-2019, 09:54 AM | #11 |
Hey cruisin, go to Tire Size.com and check out the two sizes comparison chart and that will tell you the difference in the speedometer reading using the 20 inch ZL1 wheels.
