Old 08-23-2019, 05:19 PM   #1
HokieFan
Drives: 2019 ZL1 m6
Trouble putting top down w/ fob
Sorry if this has been covered before, but has anybody else had trouble with their top going down with the fob? (Or am I just using it wrong?) I press and hold the button, and it starts out fine...but then the process freezes. After a few more tries it goes a little more. I have to repeat a few times until it's all the way down. If I do it from the button inside the car, its smooth as silk all the way down. Is this a common problem or do I need a warranty visit? Otherwise the car is a dream.
HokieFan is offline   Reply With Quote
Old 08-23-2019, 06:00 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Change the fob battery.
Old 08-23-2019, 06:29 PM   #3
HokieFan
Drives: 2019 ZL1 m6
I'll try it. Crazy though, it's a brand new ordered 2019...hoping I dont have to change the battery multiple times a year. :/
Old 08-23-2019, 08:36 PM   #4
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
The fob button needs continuous contact, and if it it's interrupted the top stops. In my case there's nothing wrong with the top or fob signal, it's just hard to push the button that long sometimes.
17rsvert is offline   Reply With Quote
Old 08-23-2019, 10:30 PM   #5
Captain J
Captain J's Avatar
Drives: 2017 V6 RS Covertible
Maybe you're not pushing hard enough to keep the contacts closed. For me, I almost never use the remote to put the top down. By the time I'm within range for the FOB to work, there's not enough time to complete the top down procedure, before I'm standing there waiting for it to finish.
Captain J is offline   Reply With Quote
Old 08-23-2019, 11:57 PM   #6
Blue_6.2
Blue_6.2's Avatar
Drives: 2019 1SS Convertible
When someone comes up with a mod that allows me to *touch* the open/close switch and have the top completely open/close, I shall construct pyramids in their honor and exalt their name in places public and private.
Blue_6.2 is offline   Reply With Quote
Old 08-26-2019, 08:49 AM   #7
RickErnst
Rick's6inNJ
RickErnst's Avatar
Drives: 2017 Vert 2LT RS V6
I have found that if the process gets interrupted for some reason (lift finger off the fob, another car crosses the path of the "beam", etc.), I have to push the unlock button before it will start moving again. There is usually a second or so delay until it starts moving again.
RickErnst is offline   Reply With Quote
Old 08-26-2019, 06:00 PM   #8
17rsvert
17rsvert's Avatar
Thanks for posting. I hadn't tried that.
Old 08-27-2019, 03:15 AM   #9
wintertopdown
Drives: 22 Convertible V8 LT1
Sometimes I have to hit the unlock button a couple times to activate the top down process
wintertopdown is offline   Reply With Quote
