Old 06-23-2019, 08:03 PM   #1
D K
Drives: C5
Performance Traction Management question
Im not sure which section to put this in, so please move if necessary..
My question is: can PTM be added to a non 1LE SS?
Either as a hardware add or some software hack?
Thanks n adv
D K is offline   Reply With Quote
Old 06-23-2019, 08:22 PM   #2
SpazmXylam
Because Racecar!
SpazmXylam's Avatar
Drives: 17 SS 1LE
I believe PTM works in conjunction with the eDiff and active suspension found on the 1LE. Even if you could flash the software onto the ECU, would still need to integrate the rear diff and fancy suspension to really make use of it.
SpazmXylam is offline   Reply With Quote
Old 06-27-2019, 05:30 AM   #3
ScaryFatKidGT
Drives: NGM SS 1LE
Yeah, it is part of the active rear diff so no.....
Go get a 1LE
ScaryFatKidGT is offline   Reply With Quote
Old 06-27-2019, 05:34 AM   #4
6spdhyperblue
Drives: 6th gen
Just use competition mode
