Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 06-19-2019, 09:44 PM   #1
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Catted Ca Catless Longtubes
Just curious on noise level difference. I have the MBRP Raceback. About to pull the trigger on a set of 1 7/8” Kooks and can’t decide if I want to get the high flow cats or just go catless. Is the noise level significantly different between the two?
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, GM CAI, Pray Ported TB
BruceWayne1LE is online now   Reply With Quote
Old 06-19-2019, 11:03 PM   #2
GreatWhiteLT
Drives: 2016 Silver Ice Metallic SS
I can tell you right now, i just got TSP 1 7/8th headers catless installed on my mbrp race axle back and the thing SCREAMS anything above 2500 RPM's. It's honestly not the for the every day driver if you cant stand a lot of cabin noise. But if it does not bother you then go for it
GreatWhiteLT is offline   Reply With Quote
Old 06-20-2019, 09:15 AM   #3
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
I have American Racing 1 7/8 headers and started catless but eventually went with some Vibrant Gesi High flow cats.
The Highflow cats won't really make much of a difference in the volume of the sound but will refine it in a good way, reduce or eliminate any rasp and eliminate that awful smell that no cats force you to deal with.
17 Camaro 2SS, M6 - Fifty | Procharger P1SC | 3.7 Pulley | Stage 2 IC | Race Bypass | DSX FF Kit | JRE Custom E85 Flex Fuel Tune | LT4 Fuel System | JMS Voltage Booster | MSD Plug Wires | American Racing 1-7/8's LT Headers Full System Catback | Vibrant Gesi HF Cats | MMS Oil Catch Can | 160 Thermo | Solo Performance J-Pipes
Dysan911 is offline   Reply With Quote
Old 06-20-2019, 11:57 AM   #4
Fast02Z06
Drives: 2018 ZL1
all my rides are catless. I absolutely love the sound of a cammed headers without cats thru exhaust. you can't go worng
Fast02Z06 is offline   Reply With Quote
Old 06-20-2019, 12:50 PM   #5
oldman
Drives: SS 6 speed of course
My car ran like shiznett and sounded like rusty tin can with no-cats, I have headers and have gone from mild to wild. Putting cats in was the best single mod I have ever done. I was going to do it anyway I just wanted the tune correct. no-cats sound like cheap Mustang exhaust IMO of course.
2016 to 2017 Stage 1, FBO, ported MSD, 103 TB, E85
2018 Stage 2, P1C, 4.0 pulley, Pray ported heads, Pray stage 1 blower cam, TxSpeed valvetrain, 103mm TB, ported MSD, 1 and 7/8 headers
2019 stage 3 Build (underway): Forged short block 10.5 CR, big loop supercharger cam 36% fuel lobe, Pray Ported Heads, 3.65 pulley D1X, stage II intercooler, 2 BOVs, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0, Kooks 2" coated, Lingenfelter injectors, ZL1 driveshaft and half shafts, wrap starter and header, ported TB, ported intake manifold, BTR valvetrain.
Old 06-20-2019, 01:07 PM   #6
BruceWayne1LE
Yea this is exactly what I wanted to hear. Not a fan of the rasp but I can live with some of it. Really just don’t want to smell the gas fumes (been there done that).
Old 06-20-2019, 01:08 PM   #7
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i have afe power longtubes with cats and they told me in cali both are illegal so it doesnt really matter but you dont really need catless unless your running alot of e85 or race gas and cats/hi flow cats not gonna be a huge power difference
2016 1SS NIGHTFALL GRAY METALLIC WITH NPP / AFE POWER SPRINGS/SWAYBARS/INTAKE/EXHAUST AND HEADERS HRE FLOWFORM FF04 WHEELS /BLACK BOWTIES/OEM SMOKED TAILS/GM FRONT LIP/CLEAR OEM SIDE MARKERS/LED LICENSE PLATE LIGHTS/OEM GM STRUT BAR/BODY MATCHES SS EMBLEMS/ CMS TUNE ON 91 OCTANE
kropscamaro16 is online now   Reply With Quote
Old 06-20-2019, 02:09 PM   #8
oldman
My car like your is a M6, IMO the M6 with no cats at low RPM sounds like a rusty Mustang exhaust. You will feel the same way... Put cats in smooth like butta… still sounds great. As noted I've gone from mild to crazy....
Old 06-20-2019, 07:32 PM   #9
paleon
Drives: 2017 Camaro 2SS
Do you need to get the car retuned if going from a catless setup initially to a catted one?
paleon is offline   Reply With Quote
Old 06-20-2019, 09:34 PM   #10
oldman
Some tuners turn off the rear o2 no matter what. There are smog reddy codes that never turnoff...soifyou have to pass smog...
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
