Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 01-17-2019, 07:50 PM   #1
Powerlovers
Drives: 2013
Oil pressure is low stop the engine now
Hello
I was speeding 230 km/h and suddenly i got oil pressure is low stop the engine now and i heard some noise from the engine and oil pressure gauge is 0 plus I smelled some oil burning if iam not mistaken
So what does it mean?
Thanks for ur help
Powerlovers is offline   Reply With Quote
Old 01-17-2019, 07:55 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
You need a new engine.
Vegas Bound is offline   Reply With Quote
Old 01-17-2019, 09:57 PM   #3
0-120
Drives: 2014 Camaro SS LS3
=143mph
That’s interesting. Have you been on top of regular maintenance? How many miles on the car?
416HP, 422TQ. Rotofab CAI, Dyno Tuned. ALP's and a V1.
0-120 is offline   Reply With Quote
Old 01-17-2019, 10:37 PM   #4
Powerlovers
Drives: 2013
I do service monthly plus the car is fulley moded
Old 01-18-2019, 01:13 AM   #5
Dylan1214
Dylan1214's Avatar
Drives: 2014 Camaro SS L99
Yep, Sounds like your motor is toast.
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
Dylan1214 is offline   Reply With Quote
Old 01-18-2019, 02:06 AM   #6
DSMer1
Drives: 14 and 15 SS's
Have you checked the oil level?
Bolt-ons!
DSMer1 is offline   Reply With Quote
Old 01-18-2019, 05:53 AM   #7
Powerlovers
Drives: 2013
Oil level is normal
Old 01-18-2019, 06:23 AM   #8
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Originally Posted by Powerlovers View Post
Oil level is normal
Bring it in to the shop that modded the car. If you're capable take off the valve covers and check each lifter. If it's deeper than that you'll have to remove the heads...or more.
JB'sZL1 is offline   Reply With Quote
Old 01-18-2019, 07:30 AM   #9
HDRDTD
Your oil pump may have failed, or possibly an oil line/fitting/cooler may have failed.
get it to the shop ASAP. Hopefully you shut it down immediately before the engine could seize up.
Old 01-18-2019, 08:44 AM   #10
Powerlovers
Drives: 2013
I did in lessa than 30 second hopefully lifter or valve
Old 01-18-2019, 09:45 AM   #11
GONMAD510
Drives: 2013 ZL1 M6
30 seconds may have been too long. Bearings start eating themselves up once they loose oil pressure. You were pushing the motor at the time of the pressure loss so the motor may be toast.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 01-18-2019, 11:52 AM   #12
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
Hello
Thanks for ur help
Is this a v6
CAM....ZL1 is offline   Reply With Quote
Old 01-18-2019, 12:22 PM   #13
JB'sZL1
Originally Posted by CAM....ZL1 View Post
Is this a v6
Hah. That's what he had on his previous posts.
Throw in a V8.
Old 01-18-2019, 06:45 PM   #14
Powerlovers
Drives: 2013
Is this a v6
Nah .. its 2013 ZL1
