TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 06-25-2014, 09:22 PM   #1
JacobC1983
JacobC1983's Avatar
Drives: 2019 ZL1
ZL1 Rear Suspension noise
Does anybody get a small but noticeable clunk noise when they go over potholes at very low speed? I hear it particularly from the right rear. I don't notice it at speed or on the highway, but with pulling up to a stoplight and going over a bump.
JacobC1983 is offline   Reply With Quote
Old 06-25-2014, 10:01 PM   #2
WillR
Drives: 2017 Hyper Blue ZL1
Yeah, I notice this as well. Especially when I am going over a portion of the road that stair steps. I got under the car to see if I can find anything loose and I noticed the rear fascia is kind of loose in the middle, figured that may be rattling when I hit the breaks in the concrete, since nothing is really bracing the center section of it.
WillR is offline   Reply With Quote
Old 06-25-2014, 10:20 PM   #3
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
JacobC1983,
I realize how displeasing it can be when faced with a rear suspension concern like this, and though you're seeking thoughts and opinions, I would be happy to communicate this situation with the designated Customer Experience Manager at your preferred dealer if you feel an official diagnosis is necessary. Feel free to message us privately if you'd like to proceed, or discuss this situation further.
Kindly,
William R.
Chevrolet Customer Care
Chevrolet Customer Svc is offline   Reply With Quote
Old 06-25-2014, 10:40 PM   #4
Samson2029
Drives: 328xi, ML400, ZL1 man. 2013
take a look at the cooling pipe of the differential on the right side. the segment near the joint of the rubber tubing to the metallic pipe may be vibrating against the heat shield when hitting road bumps. if the piping is to close to the heat shield, just bend the shield.
Samson2029 is offline   Reply With Quote
Old 06-26-2014, 06:36 AM   #5
JacobC1983
JacobC1983's Avatar
Drives: 2019 ZL1
Thanks for the thoughts, I will take a look this evening.
I really don't want to take my vehicle to the dealership. They are so behind with recalls, one dealer keeps the car for 2 days before they even get to it so it sits outside, and the other dealer books appointments 2 weeks away.
Old 06-26-2014, 05:33 PM   #6
JacobC1983
JacobC1983's Avatar
Drives: 2019 ZL1
Would you mind posting a picture where I should be looking at the heat shield meeting the rubber tubing. I tried to look for it and can't get all the way under the car to see where you are describing.. thank you!
Old 06-29-2014, 10:48 AM   #7
WillR
Bump for pic if possible. I have similar sound when driving over stair stepped concrete. Thx
Old 06-29-2014, 11:59 AM   #8
Camero5
Hide! My wife's coming!
Camero5's Avatar
Drives: 2013 Chevrolet Camaro ZL1
Same here.
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
Camero5 is offline   Reply With Quote
Old 08-20-2014, 12:12 AM   #9
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
Any update on this? I noticed the same issue with my car and I do NOT get it on the drivers side rear only the passenger side rear. It is a fairly distinct "clunk" from that side when going over a bump...
jayno20 is offline   Reply With Quote
Old 08-20-2014, 05:23 AM   #10
Emvici
Drives: 2014 ZL1 White Convertible
I don't get any kind of clunk in mine, other then I think magnet ride is so stiff, that the car is going to loosen up against itself, because somethings gotta give with a suspension so stiff.
Emvici is offline   Reply With Quote
Old 08-20-2014, 07:53 AM   #11
JacobC1983
JacobC1983's Avatar
Drives: 2019 ZL1
Still have mine, a member sent me pictures of part of the underside of the car he cut away. I wasn't able to get under the car to reach the area to even see where he had cut.
Old 08-20-2014, 01:41 PM   #12
jayno20
Go fast, please.
jayno20's Avatar
So something is hitting another piece? After that is cut away the noise stops?
Old 08-20-2014, 01:57 PM   #13
NightmareZL1
Can't stop ***ifying
NightmareZL1's Avatar
Drives: Ashen 2013 Gray ZL1
same here, getting worse with time also. right rear, clunking sound, like a loose suspension component. dealer inspected and said all was okay. no idea what it could be.
Rotofab, grinding rear diff sound forever, dealer replaced supercharger - now i have a rattle when starting from a stop, ordered 2.35 lingenfelter pulley, hp tuner, belt, 100mm idler pulley, tr7IX spark plugs, wideband kit, long tubes with no cats...hoping for 650hp. dyno with rotofab = 518hp
NightmareZL1 is offline   Reply With Quote
Old 08-20-2014, 03:30 PM   #14
JacobC1983
JacobC1983's Avatar
Drives: 2019 ZL1
This is the presented solution, but I can't get under the car to try it.
