Old 09-25-2020, 08:57 PM   #1
SS2020
Drives: Chevy camaro ss
Rear of car sits slightly uneven, side to side
hello all, I have a 2020 1ss m6, non magride. This is most likely me just being anal about the car, but just wanted some insight. If I'm parked, on as much of a level surface as I can find the passenger side rear seems to sit lower than the driver side. It's not noticeable unless you look at the gap between rear tire and fender side to side. I measured a few different times and it is like 3/8, half inch difference from ground to wheel well. Is this acceptable, or could something be out of whack? Car seems to handle fine, the only thing I can think of is I had to replace my passenger side front tire last month due to a bad flat, could the uneven wear of the fronts show themselves in the rear ride height like this? I didn't notice if it was uneven before the new front tire. Thanks
SS2020 is offline   Reply With Quote
Old 09-29-2020, 12:29 PM   #2
DC5
Drives: 2019 Chevrolet Camaro SS 1LE
What your describing is entirely normal.
DC5 is offline   Reply With Quote
