09-19-2020, 09:03 AM | #1 |
Drives: 2018 ZL1 Join Date: Sep 2016
More fuel! Worth it?
So I'm at a point where I'm ready for some more power and only thing I have left is fuel and cooling(trying to stay away from spray) so talking to my local shop and came up with a new fuel setup and I'd like some input.
2018 zl1 my Current mods- 850hp LME 377 LME heads 38% cam Whipple 9.17 lower 3.25 upper 103 TB Alky meth Headers Dsk aux pump McLeod clutch New mods would be dumping the dsx aux and going with a e85 capable dual pump system from fore innovations and heat exchanger and a CPR tank. That new fuel system just to run E is pretty pricey and not sure if it will be worth the hp gain. Last edited by 11bravoss; 09-19-2020 at 10:07 AM. |
09-19-2020, 09:48 AM | #2 |
That won’t be enough to run E at that level IMO. Your injectors and probably the HPFP will be out of luck if you try to run much E at 850 WHP. You’re looking at port injection, or +30/+65 injectors and LPE BB HPFP.
If you were on straight 93, running E would probably be worth 100+ HP due to being able to add a good amount of timing. But since you’re already running meth, you’re probably already running more timing than a 93-only car anyway. Edit: I don’t see a cam in your mod list? That would be a step to add more power of you haven’t already done so.
09-19-2020, 10:07 AM | #3 | |
09-19-2020, 11:51 AM | #4 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Why not do injectors and high side and see where you are at before redoing your low side?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
09-19-2020, 12:38 PM | #5 |
09-19-2020, 02:49 PM | #6 |
Is port injection an option for the whipple? Lot less money than the Di injectors.
09-19-2020, 09:51 PM | #7 |
Yep. You can send out the Whipple to be drilled for port injector bungs. Or, wait for @toohighpsi to finish his adapter plate design. I’m definitely doing one or the other. Even dropping $4K on +65 DI injectors doesn’t get you to full E85 on big power builds because you still have to buy the LPE HPFP and that looks to limited to around 1100 crank HP on E60 or so. They advertise 1400 HP... on VS109 race gas... Decisions, decisions...!
09-21-2020, 01:03 AM | #8 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
If you like to, or plan to track the car on a circuit the Fore will result in high-G fuel starvation below 1/2 tank. The stock pump hanger has a bucket that acts as a buffer like a mini internal surge tank.
As long as you keep the tank above 1/2 you should be fine for drag racing other non-circuit stuff. I recommend you do some research here, others have already posted about this. |
09-21-2020, 12:30 PM | #9 |
Drives: 2018 Camaro SS Join Date: Sep 2009
I believe I’d go the drilled Whipple bung route, with the injectors pointed down at the valve instead of using the Toohighpsi plates that blast fuel straight across the flow of air. It’s a good solution for a Magnuson 2650 as there is no other way. Outside of a Maggie I don’t see the value of settling for an injector spraying perpendicular to the flow of air if you don’t have to have to. Also, it is gonna make for a taller setup that pushes the blower closer to the hood. Lastly, drilling what you already have has got to be cheaper than buying additional equipment
09-23-2020, 03:29 PM | #10 |
Dyno Show Queen LOL
The shop I use has had 2 whipple cars modded with port by weapon x both have leaked at the injectors/rails. I'd see if crawford racing made a kit for it and drilled it for port if you go that way.
If it was me I'd see about doing the XDI and a good return style lowside.. tell your shop to set up an account with UWE O. at XDI to become a vendor then see if your shop will give you a discount. there is no reason you can't see where you might get on LT4 injectors if its no good get the FIC plus 30s. The LPE kit works to about 900 on full e if if you do the following.. 100 psi low side system with a regulator and able to maintain 80 psi plus on load(not DSX) I think the Holey dual will do it if you went aux style. a new low side fuel line and high flow check valve from LPE Big Bore pump 42% cam fuel lobe not a 32 or 38% 30% plus injectors
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 09-25-2020 at 02:21 PM. |
09-25-2020, 02:14 PM | #11 |
That won't be enough for full E you will still run out of high side . Keep the DSX auxiliary low side pump and ad the auxiliary XDI high side pump. They have 30% and 60% injectors also but I think you'll be fine with pump only and stick injectors.
09-25-2020, 02:24 PM | #12 |
Dyno Show Queen LOL
^ don't listen to this guy.. I've done the LPE, I have the port, and I was at the shop when Uwe from XDI set my shop up as a vendor and pushed the system on me and told me what all is needed.
09-25-2020, 02:28 PM | #13 |
I run full E85 With the XDI pump and stock injectors so I know.
09-25-2020, 02:34 PM | #14 |
Dyno Show Queen LOL
Baby power
