01-14-2019, 06:31 PM | #1 |
Drives: 45th anniversary camaro ss Join Date: Sep 2014
Retainers
Do I need to purchased new titanium retainers when I change out the springs? It`s a BTR STAGE 4 cam with titanium when it was installed.
01-15-2019, 09:51 AM | #2 |
Drives: 13' 1LE Join Date: Apr 2012
Id put new ones. 2 threads above there is a failure on Ti retainers after 50k miles.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
01-15-2019, 10:03 AM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
I used BTR steel retainers, my cylinder head guy said he does not use Ti unless its well avobe 7000 rpm.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
01-15-2019, 11:01 AM | #4 |
Drives: 2015 2SS 1LE Join Date: Dec 2016
hmmm, my cylinder head guy is the same as your cylinder head guy and he is putting Ti on my stage 3 heads
505/465: 416 stroker, landspeed stg 3 heads, 10.5 compression, btr stg 3 stroker cam, E85, kooks 1-7/8" headers,k&n intake,vmaxx tb,mgw,rxt,bmr 1.5" drop springs,bmr poly cradle bushings,bmr toe rods,bmr trailing arms,bmr uca,bmr diff bushings
01-15-2019, 11:06 PM | #5 |
LOL, not sure, ask Brett. Maybe he just off loaded some steel retainers on me. My dyno sheet showed no signs of valve float so I guess they worked out weight wise plus they are more durable than Ti.
01-16-2019, 09:07 AM | #6 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Get new valve seals/seats too.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
