Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 07-10-2017, 05:16 PM   #1
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
DSX, Fore Innovation, Squash dual pump setup?
Can anyone tell me the pros and cons of each of these? I am looking to run E85 and be around 700whp. Prices seem to be similar but I am wondering if the in take options might be better? Which would be easier to install?
jayno20 is offline   Reply With Quote
Old 07-10-2017, 06:46 PM   #2
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
DSX allows you to retain stock PCM control of fuel pressure via PWM and the FPCM. A problem unique to the ZL1's, CTS-V's and ZR1's. Dave can step in with details on that.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 07-10-2017, 07:09 PM   #3
DSX Tuning
My system keeps all the functions of the factory FPCM in place and allows for live pressure reporting. The install is also a lot faster, and all of it is plug and play. The only downside is tapping the gas tank.
I don't think the price is comparable at all really though. My system is only $1000 which includes everything (minus the drill and tap), and I offer free FPCM editing if you send it to me in order to allow a ton of pressure. 700whp will be a breeze for it. PTFE lines are standard in mine.
I'd suggest ordering it with the drill and tap to make sure you have the right tools for accessing the tank.
The system is here.
DSX Tuning is offline   Reply With Quote
Old 07-10-2017, 07:52 PM   #4
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Love my DSX setup, Aux Pump and Flex Fuel Kit, Dave did the tuning on the FPCM and tuned the car, i was providing logs with Lambda AFR.
Car runs great, hauls major ass...
I recommend 1050x injectors, i am around 73% DC with 80% Ethanol Content at 6500rpm
Crash76 is offline   Reply With Quote
Old 07-10-2017, 07:56 PM   #5
Crash76
Team 913
Even better i can send you the drill bit and tap to use... save you lil coin
Old 07-10-2017, 07:57 PM   #6
crazydave
crazydave's Avatar
Drives: 2013 Camaro ZL1 M6
Dave's system is not only 1/2 the cost, but it does almost exactly what the Squash and Fore systems do without all the extra plumbing, but in a better way. There are no new fuel feed or return lines to run to the fuel rail, no regulators to install and it allows the PCM to dictate the proper Fuel pressure for just cruising around town and make its own adjustments when under boost and more fuel is needed. The Fore and Squash systems use a mechanical regulator and are fixed pressure no matter what the boost pressure is. Ultimately all three systems do the same thing which is activate a secondary pump when boost pressure is detected and I really didn't see the point with replacing the stock FP with something that in a way is inferior since you have to disable the FPCM.. I have been racing on the DSX system for a year and a half now 300+ passes and never a hiccup, and the car runs 100% stock around town. I don't think i have read a single complaint and Dave has a lot of systems out there now. AND most importantly, Dave is VERY accessible on Facebook (DSX Tuning) if you have any questions or problems and very knowledgeable about LSA and GM platforms in general!
To sum it up, I am a very satisfied customer.
2013 ZL1 CRT M6
__________________________________________________ ____________________________________
Current Mods: Rotofab CAI, Big Gulp, and Res. ATI Superdamper and 10" Lower, DSX FF Sensor, DSX Aux Fuel Pump, ID850s, Kooks 1 7/8" Headers, Forced Induction Interchiller, McLeod RTX Twin disk. DSX Tuned. Running on 20" MT ET Street SS on stock wheels for the strip.
Best 1/4 mile to date:10.81 @130.43 mph w/ 1.61 60'
Just added: Jokerz Stage II blower port and FI Interchillers blower lid spacer.
crazydave is offline   Reply With Quote
Old 07-10-2017, 08:47 PM   #7
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
DSX, no question:
My install and dyno, excellent kit, fairly simple, and just works:
http://www.camaro5.com/forums/showth...385577&page=92
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 07-11-2017, 12:06 PM   #8
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
DSX is the best flex fuel setup.
I've seen people have problems with Fore.
Old 07-14-2017, 06:42 AM   #9
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
I agree with everything said above. I will be installing DSteck's system next week after a ton of research on the best LSA fuel upgrade.
I've been following Dave Steck since he innovated his Flex Fuel sensor years ago. Tremendous resource and tuning knowledge. There are other Vendors out there selling his systems so it can get confusing. Buyer beware
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 07-15-2017, 10:31 AM   #10
bct10985
Drives: 2010 2SS LS3, 2013 duramax
How much power will the dsx setup support?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 07-15-2017, 11:32 AM   #11
DSX Tuning
1000whp on E85.
Old 01-09-2018, 06:18 PM   #12
Devcon 7
Devcon 7's Avatar
Drives: 15 camaro
Is there any potential longevity issues while running corn with the dsx kit?
Devcon 7 is offline   Reply With Quote
Old 01-09-2018, 06:27 PM   #13
crazydave
crazydave's Avatar
Been running it for 2 years now, lots of drag strip time...0 issues. I run on 70ish for most of the year. the only thing I don't do is store the car over the winter with E in the tank.
Dave
2013 ZL1 CRT M6
Old 01-09-2018, 10:45 PM   #14
Devcon 7
Devcon 7's Avatar
Drives: 15 camaro
Dave
Good deal, I'm going back and fourth on what I want to do lol
