Old 12-27-2020, 05:00 PM   #1
Andrew S
Andrew S's Avatar
Drives: Camaro 2SS Redline Edition
Eliminate dry water marks before ceramic coating
I just bought my car. Before I ceramic coat it I want to get rid of some dry water marks that don't come off when washing.
I want to give it a light polish before coating it to get rid of a few swirls and these marks.
Can you recommend what to use? What polishing compound, and what to look for when buying a machine buffer.
Andrew S is offline   Reply With Quote
Old 12-27-2020, 06:07 PM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I used Sonax Perfect Finish to make sure my clear coat was as good as it can be prior to ceramic coating. Autopia has a bunch of good buffers from Rupes, Griots Garage, etc.
Old 12-27-2020, 06:41 PM   #3
TMD29
TMD29's Avatar
Drives: 19' ZL1, BMW F80 M3
Apex Detail has a great channel on Youtube to give you some ideas. However, I used Sonax Perfect Finish and 3D One, numerous white and orange Lake Country pads, Buff and Shine Eurofiber pads, Flex 3401 polisher, Griots G9 and GR3 polishers. Severity of your swirls and other paint defects will determine which pad you need and panel size will determine your pad sizes. Good luck.
TMD29 is offline   Reply With Quote
Old 12-28-2020, 06:53 AM   #4
Andrew S
Andrew S's Avatar
Thanks for your help.
At what stage should I fix any rock chips? Before or after polishing?
Old 12-28-2020, 04:06 PM   #5
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2014 ZL1
Definitely before as the chip pits will fill in with polish and wax and will not allow touch-up paint to adhere properly.
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
