11-13-2020, 08:44 AM | #15 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
11-13-2020, 09:07 AM | #16 | |
Drives: 2018 ZLE Join Date: Jul 2014
11-13-2020, 10:06 AM | #17 |
11-13-2020, 11:11 AM | #18 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Fortunately for those that do want it, as TrackClub pointed out, it's really cheap to buy so it's easy to handle on our own after buying the car.
2017 SS 1LE.
11-13-2020, 11:30 AM | #19 | ||
Drives: 2013 C6Z06 Join Date: Nov 2016
PLENTY of people can make stock 1LE, ZL1/ZLE brakes fade so why not get more cooling? |
11-13-2020, 12:05 PM | #20 | |
What's dumb about it? All that's happening is an explanation of why GM doesn't include these ducts with ALL trims instead of just the SS.
2017 SS 1LE.
11-14-2020, 11:37 AM | #21 |
As far as hanging low, they do and may rub. Its a $15 dollar part and plastic, so as someone said in another thread it will self clearance. I have rubbed them on some track curbing when going over the curb (very limited areas such as Road Atlanta at the exit of the uphill esses). I run them all the time and daily driving have only scraped once to twice.
Here is the difference.Running with my friend at RA Stock SS Deflectors Last edited by weemus; 11-14-2020 at 11:49 AM. Reason: Pics |
11-14-2020, 12:29 PM | #22 | |
In either case, this is the first I'm hearing of it not clearing 19s...that would defeat the purpose for me |
11-14-2020, 03:23 PM | #23 |
Drives: 1LEs Join Date: May 2009
Those SS track deflectors work with no issues on 19x11 +11 & 18x11 +10.
11-15-2020, 01:22 PM | #24 |
11-16-2020, 11:06 AM | #25 | |
And I remembered partially incorrectly on the clearance point, my bad. With the 19s there's no tire/wheel contact, but they will self clearance with the ground (worse on the 19s than they will on the 20s, obviously). You just have to deal with them flipping whatever is on the road up towards the rotors (i.e. slightly higher risk of getting stones and other crap getting wedged in the brakes). Not saying anyone shouldn't use deflectors because of that, just something to be cognizant of. I'd think slightly beefier bolts are probably a good idea too so the heads don't snap as guards clearance themselves as previously mentioned in the thread.
2017 SS 1LE.
11-16-2020, 11:57 AM | #26 |
haha yea mine are pretty scraped
11-16-2020, 12:42 PM | #27 | |
Idk about faded brakes hitting ABS on track either. I don't think I've ever engaged ABS on track. Ice mode sure and that sucks, but that's a different topic... |
11-16-2020, 02:12 PM | #28 | |
And I've gotten into ABS on track so I can confirm that at least lol. Can still consistently get it at the end of a 20 minute session on an all stock SS 1LE with good tires and high 80s/sunny/dry, that is. There absolutely is noticeable fade once everything is up to steady-state operating temps and it takes pretty significant pedal force to get into it, but it is still possible. I personally prefer having to push harder on the pedal to get to lock since it gives more room for modulation up to that point, but I know that's not necessarily how everyone else like their cars to respond and can understand the benefit of putting the ducts or other extra cooling to reduce fade. I've even had a set of ducts sitting in my garage for a few month or so with plans to see if I like them when I'm back on track, and if not sit on them until I start adding power once warranty is up. Figure for $15-20 it's worth it to find out if it maintains pedal feel to my liking while also helping temps stay a bit lower to improve longevity.
2017 SS 1LE.
