08-03-2016, 10:58 AM | #1 |
Crewel Jewel
Drives: RJT-2SS-RS-6M Join Date: Nov 2009
3 Bar Map Sensor Wiring
I'm just installing Alky Meth Kit to go with my Whipple and was wondering where others have spliced into their 3 Bar Map sensor wiring and what is the wire color.
I was considering where it runs in the loom along the fuel rail, not quite sure which wire though. If you used a better spot or have any advice it would be appreciated. Thanks
Whippled |
08-03-2016, 12:10 PM | #2 | |
find the Zero-5v output wire you will have a reading at key on engine off and another while running. You can also refer to a Factory pin out but even that can be confusing. Ted.
www.jannettyracing.com
08-03-2016, 04:55 PM | #3 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
A- Ground
B- Signal C- +5 volt source Hope this helps, but like ted said, verify it with a meter.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
08-03-2016, 05:51 PM | #4 |
Drives: 2011 2SS/RS 2004 GTO Join Date: Sep 2012
My magnacharger came with a MAP sensor extension harness, not sure if the whipple required that. That's where I tapped into the MAP signal for my gauge projector. I preferred not to cut up the factory harness. But like 1killerSS said, middle wire.
2011 2SS/RS - Kooks Headers, HFCs, Corsa exhaust, Magnacharged, Cold Air Inductions CAI, tuned by JRE
08-03-2016, 11:45 PM | #5 |
Crewel Jewel
Thanks guys
Whippled |
08-04-2016, 08:30 AM | #6 |
Connector diagram
Maybe this will help you out
08-04-2016, 09:56 AM | #7 |
See I told you it can be confusing, best to always use a volt meter.
Ted.
08-04-2016, 11:19 AM | #8 |
Right!
