02-01-2019, 12:45 PM | #1 |
Probably tired right now
Drives: 1Lap1LE | EV6 FE | 18 F150 Join Date: Sep 2010
Folks running 18x11 up front... Need some camber/offset/tire info from you
Thinking of ordering a set of custom 18x11 and 18x12s...
I wanted to know if you're running an 18x11, can you answer the following...
You're welcome to post the wheel make/model or a pic of your car but I'm less concerned with that than I am with the answers to the questions above
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
02-01-2019, 01:18 PM | #2 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
My setup probably doesn't apply to you because I'm running MCS struts, but nonetheless-
1. 315/30-18 Rival-S (square) on 18x11" 2. +43 with a 20mm spacer 3. -3.7deg, max positive at the hub, max negative at the plate 4. Yes 5. 20mm 6. No I could fit 18x11.5" with this setup and still stay under the fender, but the rules (at the time) didn't allow it. I know one person running this same wheel setup with stock struts, it requires about 10mm more spacer and massive grinding. |
02-01-2019, 01:28 PM | #3 | |
-Seven
02-01-2019, 01:50 PM | #4 |
The setup is 18x11 +43 square for the purposes of rotating. If you are going to run 335/12" in the rear then that wouldn't be a concern and you just get the front wheels made with the offset you want without spacers.
I also have a 19x11 square setup that I do the same thing with. |
02-01-2019, 01:54 PM | #5 |
I just noticed you are in the PacNW. What are you doing with the car? If it's AutoX related I'd tend toward a 19" setup because the fitment is a lot easier with stock struts. (and because the RE71R is better than the Rival-S when it's <60deg)
02-01-2019, 07:39 PM | #6 | |
-Seven
02-02-2019, 02:36 PM | #7 | |
Drives: C5 Join Date: Nov 2018
What class/tire do you race? |
02-02-2019, 05:54 PM | #8 |
They are awesome. Ran the car in both STP (defunct) and CAM-C in SCCA Solo competition. The car has multiple ProSolo Championships and has won at the Solo National Championships with the setup.
The car is gone, but I still have the suspension. It might be going on a ZL1 1LE, as I think it’s the only way to fit 335 in front without completely butchering the fenders. |
02-03-2019, 12:32 PM | #9 |
Are you selling the suspension?
02-03-2019, 01:33 PM | #10 |
Not selling right now, planning to pick up a used ZL1 1LE in a few months. If my plans change I'll post them for sale.
02-04-2019, 01:14 PM | #11 |
Were they res or non res?
Did the 'extended ear' design help with more clearance at the hub? |
02-04-2019, 04:59 PM | #12 |
They are remote reservoir triples with quick disconnects. Honestly the triples are overkill, I think remote doubles are just fine.
The extended ear helped a lot for inboard clearance. In front 19x11 +27, and 18x11 +23 both clear just fine. |
02-04-2019, 06:07 PM | #13 |
Mind taking that to PM guys?
Still trying to get some feedback from others on 18x11s
-Seven
02-04-2019, 06:21 PM | #14 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
Seven, you could call Jeff Wong at ProParts USA. He autocrosses his SS here in LA and runs 18x12s I think with Hoosiers now, Used to run 335 BFG Rivals.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
Thread Tools | |
