Old 01-31-2019, 01:50 AM   #1
shaftwhy
Drives: ZL1 Finally
Wheel well liner damage after track day
Just had my first track day. Car feels great initially. After a few sessions, then somehow couldn't put power down.
Noticed left rear significant damage in wheel well liner, the liner was almost completely torn off.
Also damages on all other corners, one corner looks like the tire was rubbing the liner? Alignment was off?
First time encounter this after 3 years of track days with M3. First track day with ZL1 and this happened. Anybody has encountered this before?
shaftwhy is offline   Reply With Quote
Old 01-31-2019, 07:23 AM   #2
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
That wasn't from the tires, definitely some debris flung up.
Old 01-31-2019, 08:12 AM   #3
VIRBound
Drives: 2018 ZL1 1LE
The driver rear liner has very little clearance to begin with. I had mine replaced under warranty because it was starting to wear through, exposing the wire harness behind it. Mine had a hole worn through after about 6 events last year. I know that there are a couple other people with similar encounters on the ZL1 1LE facebook group while tracking.
Having said that, the first pic you posted definitely looks like track debris. But the second pic looks like what I'm referring too.
VIRBound is offline   Reply With Quote
Old 01-31-2019, 09:55 AM   #4
shaftwhy
Drives: ZL1 Finally
Thanks! The second photo with liner completely torn off, is the left rear. Are you saying left rear has different clearance than right rear?
To clarify, the first picture is the right rear, second is left rear, third is right front. Left front had a hole as well but I didn't take a picture.
Old 01-31-2019, 10:16 AM   #5
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Yes, there is a wire harness (as shown in your picture) that pushes the liner out a bit. There are several threads about how owners have relocated that harness to eliminate rubbing issues on the liner. You will want to relocate the harness before you replace the liner.
Old 01-31-2019, 10:45 AM   #6
VIRBound
^As stated above, yes there's a body harness that creates a tight spot between the liner and the tire on driver rear.
I personally did not relocate the harness, as I don't want to take chances against warranty issues in the future. The liner was done under warranty and I will continue to monitor it this season.
Old 01-31-2019, 11:16 AM   #7
shaftwhy
Drives: ZL1 Finally
Thanks a lot! Wow, can't believe this is GM's unique way to ask me have less fun in a CW track. LOL.
Old 01-31-2019, 12:59 PM   #8
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
haha holy shit
Old 02-01-2019, 02:14 PM   #9
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
I've never seen damage like that on my car (SS 1LE). Could the track configuration have something to do with it? Perhaps there is a part with extreme compression?
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green)
Previous cars:
- 2018 Miata RF GT (Machine Gray/Auburn)
- 2017 Camaro 1SS 1LE (Summit White)
- 2008 BMW 135i (Montego Blue)
- 1996 BMW 328i (Arctic Silver)
R3ctivision is offline   Reply With Quote
Old 02-01-2019, 09:51 PM   #10
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
the liner and tires look terrible...the wear on the tires is obnoxious for the amount of track time you mention. I replaced my driver's liner due to a wear spot but it looked way better than yours. Weird...I don't know what else to say.
