02-19-2015, 12:05 PM | #1 |
Drives: 2010 SS Join Date: Apr 2014
Issue with installing springs
Hey everyone.
I'm trying to install lowering springs on my '10 ss. After I got the front assembled, I installed in in the car. The only problem is, the top cap (where the single mounting nut is) is loose. It's almost as if it's bottomed out on the retaining nut, but I have 1/8" of up and down play in the strut...any thoughts on this? I might be doing something wrong, I'll have to pull apart the other side and see, I just figured I'd ask advice before I pull it back apart... Thanks
-'10 1SS M6: Kooks 1-3/4" Headers, Gutted Cats, NO-Weeds Diverters, Flowmaster Mufflers, resonator delete, tint, HID's, KSport Lowering Springs, Pipeline Intake.
2016 Setup: BTR Stage 3 Cam w/ supporting mods. 2017 Setup: Corsa Xtreme catback 2018 Setup: Monster LT1-S, MGW Shifter, Navi My-Link, Led's all around -'03 Lexus GS300: A few mods -'18 2500 Cummins: Stock Bolt Ons(2015): 416HP/419TQ Cammed (2016): 471HP/436TQ |
02-19-2015, 12:33 PM | #2 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
You mean there's a gap between the top cap and the body of the car?
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
02-19-2015, 12:47 PM | #3 |
Yes sir.
02-19-2015, 02:01 PM | #4 |
If it's what I think it is then it's normal, you probably just didn't notice before taking it apart. There is supposed to be space there.
Here's a pic of another one.
2010 2SS
02-19-2015, 02:30 PM | #5 |
Interesting...I'll have to check the passenger side when I take it apart. My top bolt doesn't stick out as far as yours does either...I can't screw the cap (cover) on.
02-19-2015, 04:41 PM | #6 |
That's not actually mine but a picture I found online. I don't think mine has that many threads either but I didn't have any issue screwing the plastic cap on.
2010 2SS
02-19-2015, 07:57 PM | #7 |
Drives: Camaro Justice Join Date: Jun 2007
You should post pictures of yours so we can confirm you are good to go or not
02-20-2015, 12:35 AM | #8 | |
Drives: FOR SALE! Bumblebee 1 of 1 Join Date: May 2010
Not sure if you can see from the picture.
My 1 of 1 Bumblebee: Paint=House of Kolor Sunrise. Shaved door handles and concept handles added. Shark fin removed, concept mirrors, Showstoppers concept LED side marker lights. Wiper blades removed, muffler delete, and Range AFM disable. BMR springs lowered 1" rear and 1.4" front and added Eibach wheel spacers - 20mm rear and 25mm front.
02-20-2015, 09:46 AM | #9 | |
I can kinda see...Like I said, I'll snap a pic for you guys this weekend.
02-20-2015, 06:40 PM | #10 |
Drives: Corvettec5 Join Date: Nov 2012
Hi why is there a spacer under your strut tower brace? and do youhavea full pic of under your hood?
02-20-2015, 06:54 PM | #11 |
That's not my car, it's a picture I found online to show the top of the strut, so I can't answer your question about that brace setup.
2010 2SS
02-20-2015, 09:52 PM | #12 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
The spacer under the strut tower brace allows the GM brace to be bolted to an early 5th gen that was not built with the strut tower brace provision.
As for the top bolt on the strut, maybe the spring was not compressed enough when you assembled it. Let the weight of the car down on it and use a torx bit to hold the bolt and tighten the nut with a wrench or a socket with a hex built into it. Also there is a rubber ring you can get from a plumbing store that is a toilet part that fills that gap under the top cap.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
02-21-2015, 06:21 AM | #13 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
The top nut is to be torqued to 68lb/ft, but it doesn't actually compress the spring.
There is a spring perch retaining nut that you can't see once the strut is mounted in the car. It should be torqued to 65lb/ft. Your spring may have rotated a bit during re-assembly and now it's not "seated". I'd take the strut back out, check that it's seated and torque down that perch nut as much as possible. Then replace it in the car and torque that top nut too! |
02-21-2015, 07:40 AM | #14 | |
Drives: 2010 2SS/RS & 2007 2500HD D-Max Join Date: Dec 2014
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast |
