06-29-2017, 08:29 AM | #1 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
Ceramic coated headers yay or nay?
I was dead set on Kooks ceramic coated long tubes, but the shop I just had install my 3.91 uses non-coated American Racing headers. I asked about the coating and I was told the high quality stainless headers do not need it. I thought the coating helped with the heat as well as for corrosion protection?
06-29-2017, 08:39 AM | #2 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Yes coat them if you can afford it.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
06-29-2017, 08:44 AM | #3 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
06-29-2017, 08:50 AM | #4 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Times infinity. Definitely recommend it plus black headers look awesome
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
06-29-2017, 09:41 AM | #5 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Well, since we're already at times infinity, I'll just say "f*#k yea, get it done".
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
06-29-2017, 11:16 AM | #6 |
Started#gottalovethatblue
Yes to the infinite power get them coated! www.marylandspeed.com offers free ceramic coating for Kooks headers with the code 'FREECOATKOOKS' or at least they used to. It is a high quality coating that has a lifetime warranty just like their headers.
Just as an example for reason why you should, my buddy got Stainless Works headers with ceramic coating and did a temperature comparison between stock manifolds and the ceramic coated headers. The stock manifolds after 30 minutes of driving were 500*F while the ceramic coated long tubes after the same 30 minutes were 400*F. 100*F is a heck of an under hood temperature drop.
06-29-2017, 11:37 AM | #7 |
Instagram: Sangstah
Ceramic coating will help keep the heat down, do it!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
06-29-2017, 03:45 PM | #8 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
No need unless you want to brag about it. It's gonna get hot under the hood regardless.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
06-29-2017, 06:56 PM | #9 |
non coated headers will look like garbage down the road. Get them coated, my headers still look like the day I put them on 5 years ago.
2011 Camaro SS
1999 Camaro SS 1969 Camaro http://www.fquick.com/csmith4153 https://www.youtube.com/channel/UCKH...lQFJSUtgrNEY7w |
06-29-2017, 07:34 PM | #10 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Coat them if nothing else for looks alone the lower temperature thing is a plus too
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
06-29-2017, 08:52 PM | #11 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
My kooks came black coated even though I ordered them chrome, they just disappear in the engine bay. Any reduction in heat under hood is a win.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
06-29-2017, 10:16 PM | #12 |
Resident nomad
I never brag about it.......
Sold:
06-30-2017, 05:14 AM | #13 |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
Now's the time to do it if your going to do it and they looks so pretty when you get the back. They lose some of their shine a bit, but mine still look great after 4 years compared to if there non-coated.
06-30-2017, 05:15 AM | #14 |
Philippians 4:13
That's exactly my thoughts.
