02-17-2020, 03:30 PM | #1 |
Red Hot SS
Drives: 2017 Camaro 2SS Join Date: Nov 2013
Different brand of tires up front than in the rear.
Anybody ever done This? I am finding it hard to get the same brand of tires for the sizes I am looking for. Namely 265 x 40/20 and 305 x 35/20.
02-17-2020, 03:41 PM | #2 |
Drives: Grandad's C2 L89 Join Date: May 2017
Don't do it. You will have different performance parameters from front to rear.
2018 ZL1 1LE sw/PDR
02-17-2020, 03:56 PM | #3 |
nope dont recommend it
02-18-2020, 11:22 AM | #4 |
Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
For DD duty I run Indy 500 fronts and r888r rears, no issues.
02-18-2020, 11:29 AM | #5 |
I run Nitto 555R DR's in the rear...my fronts are definitely not DR's.
02-18-2020, 01:13 PM | #6 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
You may have to go +/- 10mm in width for the front or back. Also 305/35-20 seems a little tall, 305/30-20 might be a little closer to factory
02-18-2020, 03:14 PM | #7 |
Red Hot SS
I want to run a taller tire all around so it fills out the wheel well better. Can find the 305 x 35/20 but hard to find a tire with same height for the front.
02-21-2020, 08:04 AM | #8 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Nothing wrong with different brand up front as long as you as not tracking or doing auto cross. I run PS4S up front and R888Rs without any issues.
I recommend going with a 285/35/20 up front. That 265 is too narrow, unless you want that for drag racing. |
02-27-2020, 01:27 PM | #9 |
Red Hot SS
I want 265/40 up front and 305/35 in the rear as these are the same height. Rim width in front would be 9" and 10.5" in the rear.
