12-22-2017, 09:47 AM | #15 | ||
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
MJK3888 Instagram Link
12-22-2017, 10:02 AM | #16 |
Drives: 2013 C6Z06 Join Date: Nov 2016
You really don't understand do you...
12-22-2017, 10:14 AM | #17 |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
You realize the torsion rate on the ZL1 1LE bar is less than that of the SS 1LE bar.... right?
The ZL1-1LE bar is designed to work with a car sprung 3-4X that of the SS1LE, it doesnt need stiff sway bars. Do you understand how suspensions actually work? Spring rate and sway bars should be thought of as one package. By forgoing GM's research and testing because you think you got it figured out is just plain stupid. Sorry. You are creating a lack-luster experience for yourself. Just sayin! |
12-27-2017, 07:46 AM | #18 | |
Yes I understand how suspensions work and that the ZL1 1LE is sprung way stiffer, but unless you know for a fact that the ZL1 1LE bars are a lower rate than the ZL1 bars, then you are just assuming. I think I'll take your trophy away for that actually, because once again no one actually knows the answer to the ENTIRE POINT OF THE THREAD! If you provide proof I'll give it back to you. You are also "thatguy" who says blah blah blah factory GM did it best. We've all heard that guy too much, so no trophy there. Did you not notice I have a regular SS? I suppose you "know" that the SS bars are stiffer than the ZL1 1LE's too because my car is sprung softer too. Heaven forbid I try something different for a cheap suspension upgrade. "We are all sheep must follow the herd. OMG he did something different and wasted a whole 155 outrageous dollars and he now has an adjustable rear bar to tweak!!!!" I will tell you how a forum is supposed to work. Now that I am in possession of the ZL1 1LE bars I can go measure and compare them. I will then provide (crude) data and answer my own thread for the better of this community. I still don't have ZL1 bars to compare though, so hopefully someone else who wants to help the forum can provide me with the data for comparison. If I wasted money, hopefully I can exchange them, if not double bonus that I am showing the forum another option with actual data to back it up. If you don't want any data I can just go post about the 18 Mustang or ask why low dust pads don't stop the car very well. Those seem like very common topics that everyone cares about. |
12-27-2017, 10:29 AM | #19 |
lol do you even track your car or what because we both have and he kinda sorta knows what hes talking about?
12-27-2017, 11:20 AM | #20 | |
Keep the trophies on your shelf.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
12-27-2017, 11:30 AM | #21 | |
12-27-2017, 01:02 PM | #22 | ||
I would have greatly appreciated your help before everyone else gave zero help to the question at hand. Actually you already did help me out, I bought your taillights off of you. Thanks again for those! I'll PM you my swaybar measurements and weights then you can add them to your thread if you wish, this one is done. Idk where to even go to get actual rates tested so that is all I will be able to provide. |
01-02-2018, 11:34 AM | #23 |
Drives: 17 SS 1LE | 07 S2K Join Date: Sep 2017
01-02-2018, 11:52 AM | #24 |
"M1SS1LE"
This thread is becoming quite comical!
01-02-2018, 12:03 PM | #25 |
"M1SS1LE"
Proof? Doubt it. Shocking.
01-02-2018, 12:31 PM | #26 | |
ignore this kid. i dont think he has figured out this forum is for adults. young S2k, your time would be better spent on the honda boards...where all the other juveniles play.
01-02-2018, 05:04 PM | #27 |
Says the 'adult' who threw a fit about a Valet attendant moving his car? Source considered, easily dismissed.
Please, point out on the doll where I've hurt you... |
01-09-2018, 11:48 AM | #28 |
Drives: 2017 Camaro SS Join Date: Sep 2017
While I understand the SS 1LE is a great car I would like to think there could be improvements over what GM has provided.
Taking Fifty's spring data. Non-MRC SS Rates: 137 lbs/in (Front) 577 lbs/in (Rear) 1LE Rates: 178 lbs/in (Front) 539 lbs/in (Rear) Spring rates seem to be within the "noise". The two major variables would possibly be the MRC vs Non MRC shocks and the Non MRC SS has bumpstops that play into the suspension package vs the SS 1LE, which I don't believe it has bumpstops. Rough Swaybar Data Talked with a MFG and according to them the swaybars are increased ~21% in the front and 36% in the rear from the SS vs the SS 1LE Front Bar Rate SS - ~376lbs/inch SS 1LE - ~457lbs/inch Rear Bar Rate SS - ~115lbs/inch SS 1LE - ~157lbs/inch From a limited autocross experience with the SS 1LE, I personally think it could improve especially with various surfaces. Transitionally it is much better than my stock SS but still a little eager in the rear, not sure if that is due to the wheel widths/shocks/swaybars. I do have a Custom Koni package that I recently installed on my SS, so I should know shortly how much that will improve the car transitionally and loading it laterally. Then I will determine if I need a front or rear bar within the next couple of events. Looking at the overall data provided though, the SS 1LE improvements really seem to be just an OTS (off the shelf) sway bar solutions that a lot of MFG would have probably provided if the SS 1LE wasn't around. Maybe because the SS 1LE package came out, some MFG's may have changed their test mule to that package. To me it doesn't seem out of line to wonder if the ZL1 1LE offers stiffer bars.
Jeff Wong
ESP Camaro |
