08-29-2015, 08:30 AM | #15 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Unless GM is using the very latest Qi specs / hardware, charging your phone by cable is still going to be significantly faster, especially for those of us with Note type phones with large batteries, and 2A chargers. I haven't dug into the tech in the car, but WPC only came out with 15W wireless charging several months ago, so I'm not sure GM had time make the changes needed. If GM used an up to date Qi implementation, it could be around 60-70% as fast a cable charging (not including 2A / "Fast Charge" tech).
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
08-29-2015, 09:17 AM | #16 | |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
Can someone please post a pic of where EXACTLYthis spot is? I guess Ive missed it looking thru pics?
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
08-29-2015, 10:15 AM | #17 | |
Sent from my SAMSUNG-SM-N900A using Tapatalk
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
08-29-2015, 10:18 AM | #18 | |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
08-29-2015, 10:20 AM | #19 |
Here you go
08-29-2015, 10:34 AM | #20 |
Ok... ZERO CLUE how I missed that. Is it always just "open" like that? No cover or anything?
08-29-2015, 10:37 AM | #21 | |
08-29-2015, 10:41 AM | #22 |
Hmm... So another question. Are there things UNSAFE to sit there? Like metal coins, AA batteries, etc... Idk how this wireless charging works and that just looks like a good spot to sit things for me! Lol plus Ill nevr have a wireless charging phone so long as the things continue the bigscreen tv progression.
08-29-2015, 10:51 AM | #23 | |
Not really. It uses a field effect between two coils of wire (one in your phone, one in the car) to form a transformer to transfer power from your car to your phone. Don't worry about putting anything in that tray, if it's not a coil of wire, it won't matter
08-29-2015, 11:34 AM | #24 |
Awesome. Thank you all for the info.
08-29-2015, 01:24 PM | #25 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
That has been why the technology took off over other options, because the surface doesn't interfere with other things.
08-29-2015, 02:02 PM | #26 |
Drives: Not a Camaro at this time Join Date: Mar 2009
I wonder if this will do the trick for us iPhone peeps:
http://www.amazon.com/BEZALEL®-Wirel...g+for+iphone+6
Order Status:
2000 8/27/15 3000 9/3/15 2000 9/22/15 (Order changed) 2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum. |
08-29-2015, 02:04 PM | #27 | |
08-29-2015, 02:20 PM | #28 |
Ok cool, Yes it says Qi. Glad we have a solution for iPhone
Order Status:
