02-01-2019, 11:50 AM | #85 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
There seems to be a misconception here. This piece of foam isn't some sort of filter for air that is actually flowing into the engine this is simply a tube for intake noise to resonate through. It appears as though the original design was to not have any foam in it, but they found the A8 cars with cylinder deactivation to make unpleasant sounds when switched into 4 cylinder mode. Seems to me that the foam was just the cheapest fix to muffle those sounds out.
Pulling this foam in no way puts the engine in danger. Its simply a way to increase induction noise. No way will this void your warranty!
MJK3888 Instagram Link
02-01-2019, 12:55 PM | #86 | |||
Drives: '18 1SS 1LE Join Date: Sep 2017
I think Mister Will did a tube delete, not the simple foam removal. They would, or might, notice the tube delete, but would never notice the foam.
'18 1SS 1LE Black, PDR
02-01-2019, 01:37 PM | #87 |
Drives: 2021 Camaro ZL1 A10 Join Date: May 2013
Yes, I was talking about the entire sound tube. The post I was referring to appeared to be talking about the entire sound tube.
02-02-2019, 12:40 PM | #88 |
Take the foam out and back seat down to improve PDR sound. I'll have to try this
02-02-2019, 01:05 PM | #89 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
Do you know if this could also be done to the Corvette Stingray?
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
02-02-2019, 01:22 PM | #90 |
Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE Join Date: Dec 2016
02-02-2019, 03:03 PM | #91 |
Ok, thanks Nabush
'16 Camaro SS
02-12-2019, 03:17 AM | #92 |
Did it on my new '16 Camaro SS manual transmission, but only hear the increased exhaust noise from removing the NPP fuse. No noise increase from the engine compartment.
'16 Camaro SS
03-01-2019, 11:07 AM | #93 |
Drives: SS 1LE Join Date: Oct 2017
03-01-2019, 02:00 PM | #94 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
100% this. If you want to hear what an angry V8 really sounds like, remove your sound tube, lay flat your back seat and drive around with the windows down.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
