07-04-2017, 10:09 AM | #1 |
Search doesn't work on mobile
As title states, search doesn't work on mobile. Using chrome on android phone. Can click search, search box appears off screen. Can sometimes scroll over to find it but clicking on the box to type makes it disappear.
07-04-2017, 11:25 AM | #2 |
BOHIC
Drives: 2010 Camaro SS "Enola" Join Date: Jun 2014
Same here. When the box appears click on "go" and it'll take you to another page where you can type in whatever you want to search.
What else can I do to my Camaro?
07-04-2017, 11:32 AM | #3 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
Do yourself a favor, believe me - do a Google search for what you are looking for and then add "camaro5" after your search words, ie.. square setup camaro5.
Google indexes our site SO much better. The first results that come up will be some of what you are looking for and then you will see a link "More results from camaro5." This link will give you everything from our site for what you are searching for Hth
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
07-05-2017, 01:39 AM | #4 | |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
07-06-2017, 11:23 AM | #5 |
SABIO
I have used Google to find my own posts.
It works
