09-29-2015, 12:04 PM | #1 |
Drives: '13 LS3 Join Date: Jun 2013
Cam swap with stock internals?
Im thinking of the ls9 cam, are there any other cams out there sound stock and dont have to change any thing but the cam it self? My car is dd and around here a cam install is around $200 and im planning to sell the car in a year so im not interested in big cams and can't put a choppy cam around here. Any recommendations?
09-29-2015, 12:16 PM | #2 |
Drives: 2017 Summit White 2SS A8 Join Date: Oct 2013
ls9 cam is a forced induction cam. your not gonna see a big difference with that swap. if your selling why not just leave it stock? and where do you live that wont allow choppy cam?
Mod List: Stock (for now) |
09-29-2015, 12:24 PM | #3 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
You will gain maybe 20hp MAX from that cam. It is a whole lot of work for such a little gain.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
09-29-2015, 12:26 PM | #4 |
Drives: T Join Date: Mar 2015
x2 ^
if your having plans to sell it in a year...just leave it stock. every cam swap is going to require other things be changed. |
09-29-2015, 12:30 PM | #5 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Exactly, leave it stock, makes it easier to sell anyway.
Also, a cam change itself isnt inherently louder, I don't see why you cant have a choppy cam anywhere. |
09-29-2015, 12:31 PM | #6 | |
The LS9 cam will be soggy on the bottom compared to the stock cam. Leave it stock if your going to sell it. Ted.
www.jannettyracing.com
09-29-2015, 12:31 PM | #7 |
My car is not stock it has cai, headers, pully, tb, fast manifold, cat back. Im selling the car in a year, but $350 for an ls9 installed is a good deal for 20-30 hp in my case.
09-29-2015, 12:35 PM | #8 | |
[COTW 5/12/14]
And you have bolt-ons, that's close enough to stock. In this thread everyone is kinda meaning stock to be no internal engine mods. |
09-29-2015, 12:45 PM | #9 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
If you must go that route buy a used LS7 cam. Its got a little tighter LSA and will not be as soft on the bottom. If you dont mind some lope buy the Lingenfelter GT1 or Lunati 217/228 cam. Will make more power across the board and is a drop in. Remember you need a 3 bolt timing gear no matter what you run.
09-29-2015, 01:09 PM | #10 |
I found comp cam 214/228 is it better than ls9?
09-29-2015, 02:23 PM | #11 |
Drives: Camaro Join Date: Apr 2009
Give us a call @ Texas Speed. We can do you a custom camshaft that will meet your goals!!
09-29-2015, 02:49 PM | #12 | ||
Drives: 2014 Chevy SS Join Date: Nov 2014
Not nearly enough info to give you a thumb's up or thumb's down. Quote:
Personally......I would leave it alone....but that's just me. KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 |
09-29-2015, 10:50 PM | #13 |
Drives: 2008 VW R32, 2011 Synergy Green 2SS Join Date: Jul 2010
I would like to know where your getting a cam installed for $200.00?
09-30-2015, 01:28 AM | #14 |
Middle East
