Old 01-19-2023, 07:42 PM   #141
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Awesome build brother. Look forward to your track numbers.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 02-08-2023, 08:52 PM   #142
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Not sure if I posted my 93 run but here it is.
Cars back in the shop, having trans issues so getting it rebuilt (again).
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 02-08-2023, 09:00 PM   #143
taylorforschool@gmail.com
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
I feel that.. hopefully not ever (again) unless on my dime for an upgrade when I’m rolling in it hope you get her back soon!
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
Old 02-08-2023, 09:01 PM   #144
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Who is doing the trans rebuild?
Old 02-08-2023, 10:39 PM   #145
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
It's been quite a journey on this topic but i believe it's going to go out to pure to get rebuilt. It was originally built by someone else.
Clutches seem ok, they mentioned possibly an issue with the valve body but GM says its on backorder with no ETA.
No issues with the trans before the rebuild, basically right now its having a shift problem from 4th-5th. Sometimes never shifts, and when it does its shifting way past commanded speed. I believe also 2-3 had issues while on the dyno. Andrew was able to work most of it out via trans tune, but 4th to 5th is still a problem and im pretty sure its just applying a bandaid. Once it shifts, its not slipping or anything so really have no idea what issue is, and if its the valve body no idea how that would of suddenly failed.
Was also pulling massive amount of timing via torque management on the hit as well, as much as 21 degrees. When it did shift properly and no torque management issues it was a raped ape.
Was never right though since it came back from the rebuild though.
Since GM doesn't have a a damn valve body, may need to locate another trans and start from scratch.
So basically probably going to take the trans that's in it, sent back to builder and locate another one and send that off to get rebuilt by pure. This way can rule out any issues with valve body.
Hopefully one of them works
Old 02-09-2023, 06:38 AM   #146
PKG4U
Drives: 2018 ZL1
I’m my experience, it wasn’t the valve body. I’ve talked to 2-3 other users that have had stock trans issues, it appears the go to defense mechanicsm on these transmissions is the valve body. In all 3 cases it was not the valve body replacement that fixed the trans issues. I think it’s tactic GM uses to delay and continue giving the customer the run-a-round while they keep playing this 3 year old Covid blame game. Just my 2… not a fan of how GM handles part failures, particularly under warranty
As far as I’ve been able to tell Pure is the go to if your okay dropping a little coin. Also heard great things about Circle D converters..
Heard stangklr in a YT video about a week ago say GM is also claiming a back order on the torque converter for the 10l90.. really starts to make you wonder. If I had such a snafu with GM almost a year ago now.. if they are willing to do this with parts while the vehicle is still under production how are they going to act in 5 years when the car is in the sunset and they REALLY could give a..
Old 02-09-2023, 10:03 AM   #147
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Mines not stock, was already rebuilt. The builder thinks it’s the valve body not GM.
Old 02-09-2023, 10:38 AM   #148
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Tim King built it the last time?
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 02-09-2023, 11:48 AM   #149
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Yep.
We just located another trans and it’s going back to Tim for another rebuild.
Old 02-28-2023, 09:58 PM   #150
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
New trans is rebuilt and back at CSP.
Let’s all say a little prayer.
