08-19-2020, 03:18 PM | #71 | |
FYI, Brandon has a Hi-ram on his car.
2016 NFG 1SS A8
08-19-2020, 03:20 PM | #72 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Very true, or when PE is set to come on. Either way should be a easy fix to the A/F by adding or subtracting in 1% increments from the MAF table to fix the commanded A/F ratio versus the actual. As soon as someone offers this as a kit with it being ported as well I will probably order one for my Procharged car as well.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
08-19-2020, 03:45 PM | #73 | |
Drives: 2019 Camaro 2SS Vert Join Date: Apr 2020
It is offered now, but its an extra $300 for them to port. |
08-19-2020, 04:51 PM | #74 |
Driver for Hire
Purchased from GPI, with mods and harness, without porting.
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
08-20-2020, 07:35 AM | #75 |
Drives: like an old lady Join Date: Jun 2012
looks tricky if you want to fit a 95 mm tb. the top is even with the cast as are several places in the throat. looks like the inside ridge for the o ring has to go....? 2nd pic turned 90*, but the flashlight is shining on the top of the inside.
08-20-2020, 11:18 AM | #76 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Nice, just a little more indication that you will be sticking around with us lol
08-20-2020, 12:35 PM | #77 |
Driver for Hire
Haha! I just figured it'll be a hot ticket item, and if I don't end up in a Camaro I will sell it for exactly what I paid for it. Not trying to make a profit.
Luan Zeqollari
08-20-2020, 11:04 PM | #78 |
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
Where was this manifold two months ago when I was shopping for a replacement for the OEM LT1 manifold? This thing is making good numbers and is not giving up torque like the MSD, and the price tag is much more attractive. Nice write up, OP.
Bolt-ons.
08-21-2020, 07:27 AM | #79 |
Very creative work! But given that it is possible to adapt the IM to the LT1 and get these results I would wager that an LT1 version already exists at GM for the possible use next year or the year after. Ford sells Mustangs by adding a little HP Chevy can do the same at a very low cost.
But this effort is so cool. I had a ported MSD and while it did give about the same benefit as the LT2 IM it was super expensive for a piece of plastic. And unless I am mistaken the LT2 power is less RPM intense. Better on the street.
08-21-2020, 07:48 AM | #80 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Pray says the 95mm works on the LT2. I have a 95mm and an 87mm sitting around. Now if I could just get a LT2. Also have the wiring harness.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
08-21-2020, 04:26 PM | #81 |
Drives: 2020 ss Join Date: Nov 2019
Yes the 95mm does work.
08-21-2020, 06:04 PM | #82 |
anyone install one of these? i did it this morning. the ole girl did not like it. car was noticeably lethargic on the first drive. im skeptical it's going to be totally ok without any changes to the tune. idles and drives fine, it's getting better with mileage but acts like it's -15 degrees timing and is on a 2 second throttle input delay. after 25 miles it was definitely getting better but not like it was.
car has headers & ethanol tune. was very snappy and strong before. also opted to reuse the stock tb. i have an LT5 & adapter but was crunched on time and also did not want to modify the intake manifold knowing it's ultimately going to come off when the msd gets here.
08-21-2020, 06:05 PM | #83 |
Keep us posted what u see in the logs. Are u on E?
Vacuum leak?
08-21-2020, 06:21 PM | #84 |
Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
Confirmed that this fitting does work good.. realy strong and hose does not want to pop out. Gotta give it a lil twist and make sure ring is forward to even get it out. Air tight tested, no leak.. I did have to tap out the 1/2” black plastic fitting end on booster hose w a 3/8” bit to get it to slip over the inner sleeve on the fitting tho. But that sleeves only there if u get the dot approved fitting. Anyways, just another option.... thank u op for getting us diy guys through this
