Old 10-29-2016, 02:36 PM   #1
Pete M
9 Year USMC Vet
Pete M's Avatar
Drives: 2014 1LT black on black
E15 fuel
Saw this today.
It's higher octane than regular, but less than midgrade.
Any ideas on mileage/performance?
It's also about .10 cheaper than regular and .40 less than midgrade
A lot of stuff done so far to make it look better and be more fun to drive.....
Pete M is offline   Reply With Quote
Old 10-29-2016, 04:36 PM   #2
redcoats1976
im no expert,but id rather pay for 89 and less alcohol.
redcoats1976 is offline   Reply With Quote
Old 10-29-2016, 05:01 PM   #3
Kenny Camaro
Drives: 2013 1LT RS Camaro
Just buy premium, you won't regret it....
Kenny Camaro is offline   Reply With Quote
Old 10-29-2016, 08:50 PM   #4
jd10013
Drives: 2012 camaro
there's been a lot of problems reported from blends of more than 10% ethanol. I'd pay the extra to avoid the E15.
jd10013 is offline   Reply With Quote
Old 10-29-2016, 09:13 PM   #5
Pete M
9 Year USMC Vet
Pete M's Avatar
I usually run regular just buzzing around town, and then use mid grade for trips.
Seem to get more mpg on the highway with mid grade.
Figure my mi,eager is going to suck around town, why spend the extra on mid grade..
Old 10-29-2016, 09:16 PM   #6
jd10013
Drives: 2012 camaro
not just a mid grade vs premium thing. that e15 crap has 50% more ethanol in it and causes a lot of problems. car manufactures never designed for it. the only reason your seeing it is cause the ethanol requirements go up every year and it;s no longer possible to meet them with a 10% blend.
Old 10-29-2016, 09:26 PM   #7
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
The gov would have 15% across the board if the auto makers hadn't complained as much as they did.
CamaroFred is offline   Reply With Quote
Old 10-30-2016, 02:01 AM   #8
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
read your manual. E10 max
Old 10-31-2016, 04:28 PM   #9
deweyg63
deweyg63's Avatar
Drives: 2011 2SS/RS 500+ h.p. monster
I always put 93 in my car. Sucks when you get out west you can't find higher than 89 from what I saw. Not sure about the east coast
deweyg63 is offline   Reply With Quote
Old 10-31-2016, 04:29 PM   #10
AieaboyHI
Drives: 2011 IBM 1LT RS
It will make your check engine light go on....so probably not good.
AieaboyHI is offline   Reply With Quote
Old 10-31-2016, 04:35 PM   #11
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Premium non ethanol is all I will put in my car!
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 10-31-2016, 04:54 PM   #12
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
We get up to 91.
JLSuperfly is offline   Reply With Quote
Old 10-31-2016, 06:10 PM   #13
redcoats1976
possible to get 93 here in florida.had to run it in my 400 pontiac,glad my RS runs good on 89.
Old 11-01-2016, 06:34 AM   #14
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
This is from the 2013 manual. Vehicle fuel systems have been engineered to accept this for many years. I will still go out of my way to find only 10%. The E15 issue lies in small engine equipment. i.e., mowers, string trimmers, etc.
