07-08-2018, 03:25 PM | #1 |
Drives: 2016 2SS A8 Join Date: Feb 2016
Diff Code Decode?
Is there a cheat sheet or way to decode the sticker on the diffs?
I've attached these photos of a few diffs I've come across on eBay, but would like a way to confirm what diff I am looking at ratio wise and if it has a LSD.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA |
07-08-2018, 06:08 PM | #2 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
the middle is a 2.77 lsd. same as the bottom.
the top number is the gm part number. just have to do some google searching/ebay or gm parts sites.. not sure on the top.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
07-08-2018, 09:17 PM | #3 | |
Anyone could ask the google machine each line of numbers and Maybefigure it out, but I was looking for a Much quicker way. Kind of like decoding a car's VIN. Fifth number in the third line, if its a 9 its a LSD or if its a 6 its a open kind of deal. At first glance you can't tell much of a pattern between the three diffs. The second and third lines are the same between the three codes, and the first and fourth lines are different. The 2.0T and 3.6 might have another pattern to them.
07-08-2018, 10:52 PM | #4 | |
2.0 and 3.6 in auto will be a 2.77 open. if you narrow It down to a v8, then really all you need to possibly find is whether it was an auto or manual. the 2.0 and 3.6 auto diffs are smaller and lighter and don't have the cooling capabilities.
07-09-2018, 12:08 AM | #5 |
A 3.27 from a 3.6 1LE is what I am after as it has a cooler, but otherwise one of the other 3.27s with LSD from the manual 2.0T or 3.6 would work.
