Old 12-25-2019, 08:50 PM   #1
LT4
LT4's Avatar
Drives: all sold, getting another soon..
Two questions on Valet mode
1. Can a dealer deactivate valet mode?
2. If they can, can they put it back on without you knowing? I suspect not since they don't know the PIN you used, but just making sure.
Thanks
Larry
LT4 is offline   Reply With Quote
Old 12-25-2019, 09:30 PM   #2
caSStro18
Drives: 2018 Camaro SS
Thanks
I believe they can reset the computer which would deactivate valet mode and clear any pin numbers. But, you would definitely know because your pin would have to be reset. The only reason I say this is because they would have to have a way to do that on used cars. But it would go back to factory defaults and you would notice if they did that.
caSStro18 is offline   Reply With Quote
Old 12-25-2019, 10:11 PM   #3
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
On the topic of Valet mode, what exactly does it do? To my knowledge, it only cuts off the infotainment system and blocks access to opening the trunk.
Azerlazer26 is offline   Reply With Quote
Old 12-25-2019, 11:18 PM   #4
caSStro18
Try this...
https://youtu.be/E56RtaCng-4
Old 12-25-2019, 11:44 PM   #5
LT4
LT4's Avatar
If you have PDR, it records as well.
Larry
