Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 04-26-2019, 05:44 PM   #1
383z
Drives: 1993 Camaro Z28
Need advice dry to wet sump LT4
What would it take to swap a LT4's dry sump to a wet sump to put in a Camaro?
I have an opportunity to purchase a 2016 Z06 long block that's dry sump.
This motor is cheap cheap as the young kids would say cheap AF!!
BUT.... What would the damage be to do this swap from a dry to wet sump?
Is it as simple as replacing the oil pickup tube and the oil pan
or more cost?
I really don't want to spend another 1k.
Thanks In Advance
383z is offline   Reply With Quote
Old 04-27-2019, 03:21 AM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
it will require a oil pump and probably a crank too.
Old 04-27-2019, 12:22 PM   #3
383z
That's what I "hear" is the crank is differen, but I can't find anything about how it is different.
Old 04-27-2019, 12:30 PM   #4
chaospiece
Drives: 2018 SS, 2016 GT
Notches in the crank drive the oil system differently in each system.
Saw it in a YouTube video, don't remember which one.
chaospiece is offline   Reply With Quote
Old 04-27-2019, 12:59 PM   #5
chaoscentral
chaoscentral's Avatar
Drives: 2016 Camaro 1SS
if I recall the dry sump crank's key is shorter as it only needs to driving the timing gear. The wet sump crank has an elongated key to drive both the oil pump and the timing gear.
Red Hot 2016 Camaro 1SS 6M w/ NPP Exhaust, Speed Engineering 1 7/8" long tube headers and catless xpipe, lethal garage flex fuel kit, self tuned
chaoscentral is offline   Reply With Quote
Old 04-27-2019, 02:13 PM   #6
BowenSS1
BowenSS1's Avatar
Drives: She totaled it!
So what you guys are saying is this would not be a easy task to do, being you would need to swap the crankshaft.
so even if the motor was at 3-3.5k he would be better off buying internals for his motor?
BowenSS1 is offline   Reply With Quote
Old 04-27-2019, 02:14 PM   #7
chaoscentral
Most likely as he would probably have to rebalance the rotating assembly when switching cranks anyways.
Old 04-27-2019, 02:49 PM   #8
chaoscentral
That said though it's probably possible to run the dry sump system in the camaro but im not sure what is needed for that. Above my pay grade lol
Old 04-27-2019, 10:46 PM   #9
JCunningham
Drives: 2017 2SS M6
i dont see a dry sump system fitting into a 6th gen.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
