04-25-2019, 10:21 AM | #29 |
USA-1
The stock 2010-2011 SS setup to a 1LE setup is night and day. It's much more controlled in corners, however, definitely a bit rougher on a DD, but not too much. I got a deal on mine for $200 shipped so I couldn't pass it up.
Now, since you have an 11, you will also want new strut mounts for the front and there are these donut isolator things you will want also. My front mounts and isolators were all toast and I had about 70k miles on my 2010.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
04-25-2019, 12:17 PM | #30 |
Engineer
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jun 2015
You guys talking about these bad boys?
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP -Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing |
04-25-2019, 01:13 PM | #31 |
Drives: 2011 Camaro SS Join Date: Nov 2017
Are they back in stock? Where’d you get them?
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current |
04-25-2019, 01:30 PM | #32 |
Engineer
I got lucky and grabbed the last set in stock from a wholesaler at work. They appear to be in stock on summit though.
https://www.summitracing.com/search/...rder=Ascending
04-25-2019, 04:32 PM | #33 | |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Sent from my Pixel XL using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
04-25-2019, 05:26 PM | #34 |
Drives: 2010 2LT/RS Join Date: Mar 2015
If they are back in stock... EXCELLENT for those who are able to get their hands on them. I got tired of waiting on my order and never ending promises that I cancelled them over a year ago. Currently enjoying my Koni Orange Str.T struts. When the time comes - I might try out the Bilsteins if they are available at that time. I won't hold my breath over it though.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
04-25-2019, 06:56 PM | #35 |
Back in stock!
Yup. They’re apparently back in stock. But don’t try to order them on your own - call directly because they’re not showing up in the drop down online menu correctly. $800 for all four corners.
Just going to double check the cost of 1LE shocks before I place an order.
04-25-2019, 07:06 PM | #36 | |
04-25-2019, 11:03 PM | #37 |
What are you guys doing for the shock mounts? Not feeling the Monroe mounts - I learned from my 4th gen to go with stock mounts.
04-26-2019, 05:45 AM | #38 | |
I purchased stock mounts from GMPartsDirect.com when I did my suspension upgrades.
2010 2LT/RS
04-26-2019, 10:18 AM | #39 |
Damn, after waiting all this time for the Bilsteins to come back into stock, after checking the price again for the 1LE shocks and the mounts, I went and ordered the 1LE stuff. it was few hundred bucks less so if I don't feel like doing the install, the difference between the Bilsteins and 1LE shocks will pay for it. Hopefully I made the right choice. I figured later on if I want to go with the rest of the 1LE suspension parts it will be a better combination.
04-28-2019, 09:25 PM | #40 |
Drives: 2015 1LE Join Date: Oct 2015
Yes, I checked a couple places and they are back in stock.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
05-09-2019, 10:33 AM | #41 |
Drives: 2010 Camaro 1SS Join Date: Nov 2015
Quick question gents. Why is it that when I look these up for my 2010 Bilstein's site shows these are compatible but when I go to Summit it says the fronts don't work with my car?
05-09-2019, 09:50 PM | #42 | |
Rear Mount
Possible the mounts are different, I know rear 1LEs are different a little stiffer.
Orange Krush II
