12-13-2018, 12:03 PM | #29 |
Drives: SS 6 speed of course Join Date: Jan 2016
He was talking engine HP...
12-13-2018, 12:05 PM | #30 |
I better to say engine HP, as FWHP, means Front Wheel HP.... just saying
12-13-2018, 02:07 PM | #31 |
Drives: 2013 SS Join Date: May 2013
In this industry WHP is used, been a long time since I've seen people use "fly wheel HP" like a long long long loooooooong time.
12-13-2018, 02:13 PM | #32 |
Then you are NOT old enough. The reference was 1/4 mile speed = a certain amount of ENGINE HP. That is all, and please many threads here talk about engine HP. Lingenfelter, Hennesy, and ALL OEM advertise engine HP. Engine HP is far more accurate then this mythical, STD, SAE, wheel, hub, programmable load "wheel HP".
12-13-2018, 04:55 PM | #33 |
About 80% of people if asked how much power they MAKE they will tell you whp.........only ones wanting to feel better will say Fly wheel HP
12-13-2018, 06:19 PM | #34 | |
BAMF SS
The point of the post is that it's close enough that it can be achievable, if someone really wanted the bragging rights, and wanted to put forth the effort.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
12-13-2018, 09:28 PM | #35 | |
As an example Hennesey uses STD so why use it? It is ricer HP / unicorn HP. The people that use are purposely distorting the dyno figure to puff it up. So why use it? As an example feel free to post the actual as measured HP your car actually put the rollers CF= 1.0 and we can then see how much pretend as did not exist, HP the STD aka unicorn HP added. I believe the last factory use of STD was 1971.. just saying. Your 500+ STD HP is about 478 SAE,I would assume you did everything to max that, and just tossed in the 60 PSI as a red herring. But as stated, just post your actual HP that car put to the rollers.....
12-13-2018, 09:30 PM | #36 |
90 percent of the statistics are made up
12-13-2018, 09:43 PM | #37 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
We are rated at 455 flywheel hp. SAE certified under the new standard. No way in hell we are getting 150 hp from E85 tune, headers, cai and intake manifold. A large majority of the gains with these cars at the track is removing torque management and trans tuning. IMO a full bolt on car is around 575 flywheel horsepower. If that. And results will vary at the track wildly depending on tune, weight and conditions. I just don’t see 600+ hp. FBO mods are proven for about 100 rwhp over stock. ~400 rwhp stock vs ~500. 550-575 flywheel hp.
You simply don’t gain 150 hp over stock from bolt on mods and E85. And nobody has dyno at 550 rwhp with bolt ons. Even in the best conditions and happiest dyno 550-575 flywheel hp is my opinion for a Max effort bolt on car. It’s already pretty obvious that drivetrain loss is only about 10%-12% these days Numbers will also be all over the place because not everyone dynos in the proper 6th gear. It’s a crap shoot extrapolating rwhp to fwhp. But no way in hell I’ll ever believe 150 hp gain from bolt ons with an NA SS Last edited by ULTRAZLS1; 12-13-2018 at 09:53 PM. |
12-13-2018, 09:54 PM | #38 |
Drives: 2017 Camaro SS 1970 chevelle SS Join Date: Oct 2016
12-13-2018, 09:56 PM | #39 | |
HP mag did a bhp of the lt1 at 495 SAE 518 STD, headers (with mufflers), smooth dyno intake, no water pump, cool water. They list the cooler water temp as +10 HP. No acc about 10 HP I'm kind of thinking like you; but the trap speed does not lie, and there is only so much weight to take out of a street car. So my thinking is under great DA, you can see say 4% more actual engine HP than SAE conditions, and probably the car is pretty stripped, low fuel, light rims, and the Oldlday driving she's on 98 lbs...
12-13-2018, 09:58 PM | #40 | |
You were only 380 std stock in 6th gear? That ridiculously low. SAE in 6th gear is usually around 400. Let alone std. but that depends on conditions |
12-13-2018, 10:15 PM | #41 |
long story short, you going to have to do a cam, and IMO, the AFM cams have too much compromise...My build would be pray ported intake, 93mm pray ported TD, E85 conversion, tune, 2" LT, off road pipes, stock box cut with green filter, the above 113 LSA AFM delete cam, nice top end, over 500 whp, and STRONG mid range, much stronger than stock, perfect for road race. You have to pull the heads so that would add 8 lifters, trays, bolts, head gaskets, and 4 hours. You need real valve springs too. So $500 or so more than a straight AFM cam with inexpensive conical springs and 4 hours. But if you are bucks down AFM cam $440, cheap springs 110 bucks, cam bolt and 2 cheap water pump gaskets should cove the cam swap... absolutely the cheapest way to go then:
AFM compatible cam, cheap springs, E85, 2" LT with offroad pipes, tune. Probably is just going to do it. Next mods would be the Pray ported intake and 93 mm TB. Then CAI, either RotorFab or modify the stock setup.
12-13-2018, 10:48 PM | #42 |
No e85, would also mean ported heads and real cam
