12-03-2018, 07:27 PM | #1 |
Drives: 1LEs Join Date: May 2009
NEW CA Performance V8 Cat Delete Pipes
NEW CA Performance V8 Cat Delete Pipes - should work on SS and ZL1. No waiting on them to make some more. $320 (insured shipping in Lower 48, no P.O. boxes, PayPal address must match the shipping address).
http://caperformance.com/product/test-product/ They charge $349.99 plus shipping. Last edited by RUQWIKR; 12-03-2018 at 09:06 PM. |
12-05-2018, 12:07 PM | #2 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Is this a direct bolt on or does it require cutting?
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
12-05-2018, 01:11 PM | #3 |
Bolt on. O2 locations are the same and front and rear flanges are the same. Flows better than gutted cats due to lack of turbulence. I just did not do them because of SCCA rules for class I want to potentially run.
12-05-2018, 08:56 PM | #4 |
SOLD thanks
12-06-2018, 08:27 AM | #5 |
Just make sure to order this clamp for the drivers side slip connection and you are golden. They will leak if you try to use the factory clamp.
https://www.jegs.com/i/PYPES/958/HVC...kaAk_KEALw_wcB
2016 NFG 1SS A8
12-14-2018, 07:18 PM | #6 |
Drives: 2017 RED HOT SS Join Date: Feb 2013
Does anyone know if this will throw a code ...if the check engine light will come on ?
12-14-2018, 07:32 PM | #7 |
Of course it will unless you tune it or use the Big Daddies Garage o2 sims(no foulers).
2016 NFG 1SS A8
12-22-2018, 01:46 PM | #8 |
Just installed the cat delete...and used the clamp that King LT 1 recommended..and no codes ...yet ...
Throttle response is definitely snappier and the sound was what I was after .. |
12-22-2018, 08:55 PM | #9 |
Drives: 2017 Red Hot 1SS 1LE Join Date: Aug 2016
I'm looking for a set of these if anyone has them!
